Dana Air Compressor Relay
Yes it is the same.
The connections MUST BE TIGHT to avoid heat at the connection.
We carry the correct connectors and parts.
On Wed, Sep 25, 2019 at 5:40 AM John R. Lebetski via Gmclist <
> Wouldn't it be same as Hi blower?
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
http://www.appliedgmc.com
Ken,
It looks very much like a horn relay and it’s function from the wiring diagram shows it to be a simple relay.
I’ll compare it to a horn relay.
Larry Davick
A Mystery Machine
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
One caveat might be the duty cycle rating of the relay coil.
HI blower relay would be a continuous duty coil, horn relay is
intermittent duty.
Intermittent duty coils will heat up when energized continuously and may
quickly burn out after a short period of time.
Relay contact current rating may also be an issue. Blowers and
compressors are probably higher current devices than horns.
Stu
> Ken,
> Larry Davick
> A Mystery Machine
>> John Lebetski
>> Woodstock, IL
>> 77 Eleganza II
>> GMCnet mailing list
