D vs E rated tires
thomas g. warner
1,863
Believe that all coaches came with Generals than. Still the D rated tires
will not take the side loads imposed on them.
>In a message dated 4/9/99 3:05:22 PM Central Daylight Time, warner
>writes:
>> And
>> GM did not KEEP the D rated tires on the coach, they were recalled and
>> changed to E rated. Not a matter IF the D rated tires will blow but WHEN.
>> Are you really willing to risk your families safety for a few dollars?
>You might want re-check that recall - IIRC it wasn't all ""D" rated tires,
>just Generals - I blew out several before throwing them away and buying
>Mich's - about 60 days prior to the recall - lost about $1,000
>Lanier
>"black cloud"
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>warner
>writes:
>> And
>and
>WHEN.
>dollars?
>tires,
>buying
>Lanier
>"black cloud"
Just about everything was recalled in the late 70s. The Generals that
came new with my GMC were recalled,I went to Firestone Steel and they
were recalled, when the replacements wore out I went to Michellin and
they were replaced under warranty more times than I can "recall!"
That is why when I got 44k miles out of my Bridgestones before I had a
blowout, I was ecstatic. Now I run Bridgestone all steel E rated and
expect they will outlast me.
David Lee Greenberg
GMC Motorhome Registry
200 MacFarlane Drive
Delray Beach, FL 33483-6829
