Cylinder Heads
voyager
155
I have a 455cid motor in my 74 GMC. I just had the heads redone. Getting
ready to put them back on. Is there a Right and a left? I cant see a
diffrence
between the two.
Thanks,
Rob Teed 74 Painted Desert
Yup. Exhaust ports go out.
With that out of the way, check for the accessory mounting bosses for the AC
and alternator. They go on the front, and there are probably none on the
back of the heads.
Mark
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of Rob Teed
> Sent: Friday, February 05, 1999 7:45 PM
> To: Gmcmotorhome Org
> Subject: Re:GMC: Cylinder Heads
> diffrence
> between the two.
> Thanks,
The accessory mounting bosses are on both ends.
Guess it won't matter which side I put them.
Thanks,
Rob Teed
> [mailto:owner-gmcmotorhome]On Behalf Of Mark Grady
> Sent: Friday, February 05, 1999 7:50 PM
> To: gmcmotorhome
> Subject: RE: GMC: Cylinder Heads
> for the AC
> back of the heads.
> Mark
Same part number for both left and right in the parts book.
Ted Schurman
73 Glacier VA
> Thanks,
> Rob Teed
Thanks Ted.
Thats great info. I was afraid I would put them on wrong and
mess something up.
Rob Teed
> [mailto:owner-gmcmotorhome]On Behalf Of Ted Schurman
> Sent: Saturday, February 06, 1999 4:48 PM
> To: gmcmotorhome
> Subject: Re: GMC: Cylinder Heads
> Ted Schurman
> 73 Glacier VA
> > Thanks,
> > Rob Teed
Rob,
Be sure your tapped & threaded holes for your pump mounts etc. are foreward
and bolt em up.
Hope this helps,
Jim Bounds
>diffrence
> between the two.
>Thanks,
Jim Bounds/Co-op Motor Works Orlando www.gmccoop.com
Thanks Jim...either end has the boltholes . Guess there reversible.
> [mailto:owner-gmcmotorhome]On Behalf Of Jim Bounds
> Sent: Thursday, February 11, 1999 12:26 PM
> To: gmcmotorhome
> Rob,
> are foreward
> and bolt em up.
> Hope this helps,
> Jim Bounds
> >diffrence
> > between the two.
> >Thanks,
