CV Joint Question
joe ricke
28
Hello all,
Installing 3.55 final this week. Note I have the 1 ton front end.
When I moved the drivers side axle into place to mate with the final drive, I heard a slight 'pop' and the saw the stamped piece had come free from
the CV housing. I position the stamped, round piece into place (by hand) and put three fasteners in to sandwich the parts together.
I stopped at this point wondering if the stamped piece needs to be press fit into the housing or does it get held in place when assembled to the final
drive.
Curious if anyone has experience or thoughts if I need to remove the axle and peen the stamped end piece into the housing.
Seems to me that the pressed in stamped piece would be a bit flimsy if it is intended to be a stop for the CV joint internals.
Thanks
Joe Ricke - KE0CPM
Arden Hills, MN
'77 Transmode
> Hello all,
> from the CV housing. I position the stamped, round piece into place (by hand) and put three fasteners in to sandwich the parts together.
> final drive.
> Thanks
Joe,
That is easy to do when wrestling a drive axle. I believe that part is retained by the drive flange so you should have no worry.
You will need to stake that metal shell as there is a big thin O ring there.
Next time grab the axel and pusit on the Final drive, not pulling on that
inner const drive as the outer joint does allow the shaft to float out.
On Wed, Oct 7, 2020 at 5:14 PM Matt Colie via Gmclist <
> > Hello all,
> > final drive.
> > Thanks
> Joe,
> Matt
> GMCES
http://www.gmcrvparts.com
Jim K
I did not see an o-ring or a groove for one... This is a 1 ton set-up
Joe Ricke - KE0CPM
Arden Hills, MN
'77 Transmode
Thanks Matt.
My only worry is if the 1 ton set-up creates the hard stop like I the original design did.....
Joe Ricke - KE0CPM
Arden Hills, MN
'77 Transmode
