Curb weight
mills2
31
>For what it's worth, Page 1 of the 1977 Motorhome Operating Manual is titled
>"Important Information on Vehicle Loading". Here is an excerpt.
>GVWR rating 11,700 lbs
>Front Curb weight 3,670 lbs
>Front Cargo and Passenger load 530 lbs
>Total 4,200 lbs
>Rear Curb weight 6,590 lbs
>Rear cargo & Passenger load 910 lbs
> Total 7,500 lbs
>Total maximum weight at ground 11,700 lbs
>Note: GM's definition of Curb weight is the maximum weight of the vehicle
>wihtout driver, passengers, or cargo, and empty fresh water, LP, and holding
>tanks, but does include fuel and coolant.
>Now for some grade school type arithmatic.....
>4,200 divided by 2 = 2,100 lbs load per front tire at GM recommended maximum
>wt.
>7,500 divided by 4 = 1,875 lbs weight on rear tires at GM recommended max.
>wt.
>How do these weights compare with your tire's capacity?
>How does your coach's actual weight compare with the recommended GVWR
curb weight is all well and good until you apply the brakes and your coach
experiences weight transfer to the leading axles ( both the front axle and the
leading rear) I don't remember the formulas any more, but in a hard braking
situation the weight transfer is considerable.
Jim
'73 Canyon Lands
