Correct Oil Line Fittings ??
SteveW
567
44
28
Greetings from Southern California
I'm wondering if I have a correct assembly for JR Slaten's oil cooler lines and a Griffin aluminum radiator.
I've got things apart with a timing chain replacement project...
It looks to me like the original installer of the aluminum radiator used an externally and internally threaded reducer between the radiator connection
and the hose connection. Is that an extra part ?? Is the proper assembly a single brass connector between the hose and the radiator ?
http://www.gmcmhphotos.com/photos/member-galleries/p65690-correct-oil-cooler-line-fittings.html
THANK YOU for and commentary and or advice.
Steve W
1973 23 Yellow
Southern California
The JR Slaton part is correct.
Should the brass fitting on the Al. radiator not match, then privious owner
did some mod.
We sell few a week so we know.
On Fri, Dec 21, 2018 at 8:26 PM Steve Weinstock
> connection
> Steve W
> 1973 23 Yellow
> Southern California
http://www.appliedgmc.com
You do want to use the copper sealing washers supplied with J.R. s lines.
--johnny
Braselton, Ga.
