Cooling System Corrosion
May 4, 2007
150
16
Disclaimer; Must be true I read it on the internet ref. A. Lincoln.
I have successfully used an oxalic acid to clean solder corrosion at the tube ends. It was a 2 part; part A was a cleaner and part B a neutralizer.
That 25 years ago; fixed the coolant flow and improved the running temperature. Definitely not recommended for aluminum components and no longer
available at Autozone or Advance Auto. At the time I could visually confirm the effectiveness of the treatment.
Here is a nice explanation of corrosion inhibitors
http://www.lytron.com/Tools-and-Technical-Reference/Application-Notes/Preventing-Corrosion-in-Cooling-Systems
There are references to using muriatic acid (hydrochloric acid) to clean cooling system. I would NOT try this venue unless it is a "nothing left to
lose" and not under any circumstance with aluminum.
1977 Eleganza II
Ogden NY
One thing the article doesn=E2=80=99t tell you is that most coolants includ=
ing Prestone, Peak and other major brands use corrosion inhibitors that wil=
l normally protect for about 3 years and then they begin to be depleted to =
the point where they are not longer protecting.the system. Some think that=
they can just buy a can of some sort of inhibitor at an auto parts store a=
nd add it to their system. However the antifreeze packaged by the manufact=
ure used a combination of inhibitors, anti-foam agents and water pump seal =
lubricant that were compatible with each other. Adding an unknown can of i=
nhibitor might cause it to interfere with one of the original components an=
d cause more harm than good. So, it is always a good idea to dump out your=
radiator and refill with fresh antifreeze and distilled water. This also =
gets rid of any solids in the system that are a result of the inhibitors re=
acting with the metals to protect them. The freeze point of the solution w=
ill not change but testing your radiator for the freeze point doesn=
=E2=80=99t tell you the condition of the antifreeze corrosion inhibitors an=
d other necessary additives. I worked for Dow Chemical back in the 60=
=E2=80=99s 70=E2=80=99s and early 80=E2=80=99s. At that time Dow was the s=
econd largest producer of ethylene glycol automotive antifreeze. Union Car=
bide (Prestone) was the largest and DuPont (Xerex) was the third. Since t=
hen Dow has purchased Union Carbide and recently merged with DuPont so they=
are the world=E2=80=99s largest producer of antifreeze. I used to mar=
ket Dow antifreeze to the major automotive companies, GM, Ford, etc. I als=
o sold private label to most of the oil companies such as Mobil, Standard O=
il, Sun Oil, Quaker and others. Dow sold it to them in their labeled cans.=
Back then Dow=E2=80=99s recommendation was to replace the antifreeze =
in ones vehicle at the end of the second year of use. I still do that tod=
ay and have never had a corrosion problem with any vehicle that I have owne=
d. I also replace the pressure cap every two years at the time I chang=
e the antifreeze because most of them loose their pressure holding ability =
after about two years. This is due to the weakening of the spring and the d=
egradation of the two seals in the cap Sure, the antifreeze may have l=
asted longer than two years so I might have spent some money that didn=
=E2=80=99t have to be spent. But I think that never having had to replace =
a radiator or water pump due to corrosion over the 39 years I have owned my=
GMC has more than offset any extra expense from changing the antifreeze=
sooner. Emery Stora 77 Kingsley Frederick, CO > On Jan=
3, 2018, at 5:39 PM, Ernest Dankert wrote: >=
> Disclaimer; Must be true I read it on the internet ref. A. Lincoln.=
> > I have successfully used an oxalic acid to clean solder corrosion=
at the tube ends. It was a 2 part; part A was a cleaner and part B a neutr=
alizer. > That 25 years ago; fixed the coolant flow and improved the run=
ning temperature. Definitely not recommended for aluminum components and no=
longer > available at Autozone or Advance Auto. At the time I could vis=
ually confirm the effectiveness of the treatment. > > Here is a nice =
explanation of corrosion inhibitors > > http://www.lytron.com/Tools-an=
d-Technical-Reference/Application-Notes/Preventing-Corrosion-in-Cooling-Sys=
tems > > > There are references to using muriatic acid (hydrochlori=
c acid) to clean cooling system. I would NOT try this venue unless it is a=
"nothing left to > lose" and not under any circumstance with aluminum.=
> -- > 1977 Eleganza II > Ogden NY > > _______________________=
________________________ > GMCnet mailing list > Unsubscribe or Change =
List Options: > http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcn=
et.org
Better knock on some wood Emery. ;)
Sully
77 eleganza 2
Bellevue.
> One thing the article doesn’t tell you is that most coolants including
> Prestone, Peak and other major brands use corrosion inhibitors that will
> and add it to their system. However the antifreeze packaged by the
> manufacture used a combination of inhibitors, anti-foam agents and water
> pump seal lubricant that were compatible with each other. Adding an
> unknown can of inhibitor might cause it to interfere with one of the
> original components and cause more harm than good. So, it is always a good
> idea to dump out your radiator and refill with fresh antifreeze and
> distilled water. This also gets rid of any solids in the system that are a
> result of the inhibitors reacting with the metals to protect them. The
> freeze point of the solution will not change but testing your radiator for
> the freeze point doesn’t tell you the condition of the antifreeze corrosion
> inhibitors and other necessary additives.
> I worked for Dow Chemical back in the 60’s 70’s and early 80’s. At that
> time Dow was the second largest producer of ethylene glycol automotive
> antifreeze. Union Carbide (Prestone) was the largest and DuPont (Xerex)
> was the third.
> Since then Dow has purchased Union Carbide and recently merged with DuPont
> so they are the world’s largest producer of antifreeze.
> I used to market Dow antifreeze to the major automotive companies, GM,
> Ford, etc. I also sold private label to most of the oil companies such as
> Mobil, Standard Oil, Sun Oil, Quaker and others. Dow sold it to them in
> their labeled cans.
> Back then Dow’s recommendation was to replace the antifreeze in ones
> I still do that today and have never had a corrosion problem with any
> vehicle that I have owned.
> I also replace the pressure cap every two years at the time I change the
> antifreeze because most of them loose their pressure holding ability after
> degradation of the two seals in the cap
> Sure, the antifreeze may have lasted longer than two years so I might have
> spent some money that didn’t have to be spent. But I think that never
> having had to replace a radiator or water pump due to corrosion over the 39
> sooner.
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > On Jan 3, 2018, at 5:39 PM, Ernest Dankert
> longer
> > 1977 Eleganza II
> > Ogden NY
I'm with Emery on the 2 year plan with standard EG green coolants. I shy from any flush additves as chemical attack on the edges of gaskets is likely
to continue after you "rinse" the flush away. If you have ever adjusted the pH in a swimming pool you will understand how relatively little powdered
chemicals are needed to adjust (or screw up) the pH in say 20,000 gallons of water. We have much less liquid to dilute the imbalance
John Lebetski
Woodstock, IL
