Coolant flow diagram in GMCMI Winter 2020 backwards?
RF_Burns
Super Moderator
Staff member
Sep 7, 2008
5,151
1,352
113
Ontario Canada
So.. full disclosure, I am only a farmboy mechanic so I'm no expert in anything... but isn't the coolant flow in the Winter 2020 edition of GMCMI
magazine Tech Corner, flowing backwards?
Should not the hot coolant flow out of the top of the engine through the opened thermostat to the top of the rad??? And the cool coolant flow from
the bottom of the rad into the bottom of the engine?
If the diagram is right... as soon as the coolant in the engine gets hot enough to open the thermostat, cold coolant would then flow through the
thermostat and immediately close it... leaving hot coolant in the rest of the engine.
I did not go look up other diagrams, so maybe I am dead wrong here... but if so it challenges my farmboy engineering skills.
The image is credited to Encyclopedia Britannica Getty Images so I am assuming this diagram has been checked over by those in the know...
Or maybe is this like electron current flow vs conventional (hole) flow??
Bruce Hislop
ON Canada
Well, on mine it flows out of the thermostat housing into the upper radiator inlet, then out of the bottom radiator outlet to the water pump for
distribution.
--johnny
Braselton, Ga.
> from the bottom of the rad into the bottom of the engine?
Bruce,
Your suspicions are correct. The flow indicated on that diagram are reversed.
While there was some discussion that it might have been copied from a Chevy LT1 manual, is even wrong for that and incomplete too.
If you care, you can scroll back to 18 March and look for "Winter 2020 Vintage RVing".
Hope you are both well and comfortable.
It is simple to explain. Graphic Artists are not mechanics. Neither are
most proofreaders and publishers.
"BONEHEADS" come in all professions.
Salem, Oregon
On Sun, Apr 12, 2020, 7:59 AM Matt Colie via Gmclist <
> of the engine.
> Bruce,
> reversed.
> Vintage RVing".
> Matt
Matt,
Sorry I missed your post, I was driving home from Mexico at that time.
Interestingly when I tried to search for your posting using "winter 2020" it hits on my post, but completely misses yours. But if I search on "winter
2020 vintage" it finds your post and others in the thread.
Another reason to remind others to use the Google backup of GMCNet when doing searches as it uses Google's search engine.
Bruce Hislop
ON Canada
