Final drive to transmission is a regal bitch to do without screwing up that
duplex seal. Then it leaks out of the weep hole. I always support the
engine from above, and lower the transmission and final drive as an
assembly. Install it the reverse. Mate them on the bench with good
lighting. Screwed up a couple of them trying to just do the transmission. I
absolutely hate doing stuff over. Ruins my whole day.
On Mon, Aug 3, 2020, 10:34 AM Jon Roche via Gmclist
wrote:
> Larry-
> Thank you. those seemed to work, but copper washer was hard to find. I
> had to drill one out. I will get some more copper washer's made up and
> get
> you the rest that are left.
> Update - GMC club helped provide a good core for rebuild- I picked that
> up from Steve Turnquist. spent the rest of the afternoon finding some
> lines and such to get the tranny cooler plumbed up, and bought 4 gallons
> of ATF.
> We installed the transmission later Saturday afternoon. I was surprised
> at how tight of a fit it was. My experience was to get the bolts just barey
> started on the final drive, then level and adjust the engine to
> transmission, and it seemed to go into place. Getting the upper tranny to
> mount
> bolts was also a little bit of a careful manipulation of the
> transmission. Work was all done on a lift, I thank my lucky stars I did
> not have to do
> this in my driveway or on the road. Kudo's to those that have done that.
> Saturday we plumbed in the lines, and installed the tranny cooler. then
> unfortunatly the test drive showed a leaking problem. After many
> cleanings and checks, it is determined it is leaking between the final
> drive and transmisison. I did not think we had issues with that gasket on
> install, but it is not the easiest thing to see. The other thing I am
> questioning as I have never had this problem when installing final drives
> and
> such in the past, was the gasket we used. It was a gasket that came
> with the transmission rebuild gasket kit. I don't know the maker of the
> gasket. I just know in all the other 3-5 that i have done over the
> years, I have always installed a fel-pro gasket. Just strange, but we got
> the
> leaking to slow, but not stop by tightening up the bolts. (they were
> torqued- but now they are over torque and still having leak- just less).
> so back to stupid job I have, and need to find some time to go pull the
> final drive and install a new gasket and hopefully that will take care of
> the
> leak.
> Jon Roche
> 75 palm beach
> EBL EFI, manny headers, Micro Level, rebuilt most of coach now.
> St. Cloud, MN
