Converter recommendations?
ralph d. edelbach
107
Noticed that my converter -- looks to be original -- doesn't always want to
work even though it hums up a storm. Any recommendations about which models I
should check out? What are some of the differences that more experienced folks
have found and what sources do you recommend?
Thanks for the advice.
Ralph Edelbach, '74 Glacier (still being gone through!)
Quite a few years ago I changed to a solid state setup that I got from
Caspro. It's actually 2 30 amp units running in parallel. It has a quick
charge setting and a normal. I've only used the quick charge once or twice
when I was trying to charge house battery quicker with the Onan.
It's silent. I found room in the rear left corner inside coach behind
generator area.
BTW, to take the inverter out of the system I simply unplugged it. It's
physically still in place as it's buried under the fridge area in space that
I couldn't easily reclaim anyways.
Heinz
> Subject: GMC: Converter recommendations?
> always want to
> experienced folks
Ralph,
Those old power supplies use what is called ferroresonant technology. I've
had to repair mine twice in the past year. Most recently when the starter
bracket broke off the generator while the generator was running it burned
the terminals off the coach battery and also blew the comvertor. I don't
know if it was the short itself or the transient that caused the problem.
Inside the convertor there's a huge transformer, a rectifier, and some big
AC capacitors. These capacitors resonate with the transformer winding and
are the basis for the voltage regulation. Mine is a Triad unit and it had a
pair of 4 uf 650vac caps connected in parallel inside. Last fall one of
these caps was shorted and last week I replaced the other one. I had
difficulty locating the 4u caps and when I finally did they were very
expensive so I repaced each of them with a pair of 7.5 u @ 370vac caps in
series. It now works just fine and is now back inside humming away. So yours
is probably repairable if you can find someone to do it at a reasonable price.
The problem with these old beasts besides the amount of iron in them is that
they draw a lot of standby power. If my memory is correct mine drew about 70
or 80 watts standby with no load. This is enough to make the transformer run
hot and is more power than I want to leave plugged in full time when the
unit is parked at home. I then retrieved a similar unit from an RV that I
had sold to a friend. It's stand by power was pretty much the same. My GMC
is a '75 and the other RV was a '79 and the two supplies were very similar
but not exactly identical.
As the next step in this saga I obtained a more modern supply from an rv
surplus place.
The modern units are wired differently. On the GMC the coach battery is on
line all the time and the supply keeps it charged. On the newer stuff when
on AC the battery is switched off line and is trickle charged while raw
rectified AC is fed to the coach itself. The problem with this system is
that many solid state items won't work from unfiltered DC. I assume that
newer RV's must route both raw power for lights and battery for the critcal
things. This is probably technically a better system since there would be
less cycling of the batteries. I didn't want to get into making changes so
I returned that supply to the dealer.
In this same time frame I was getting back into ham radio after being out
for 30 years. I purchased an Astron RS-35 (http://www.astroncorp.com) supply
for use with the ham gear. This supply is regulated and filtered at 13.8v.
It would be a candidate for a replacement unit but since it's not designed
for use as a battery charger I would assume that it would drain the battery
when unplugged. Astron also sells a line of switching supplies that are much
smaller and presumably more effecient. Last fall I sent an email to Astron
asking some specifics for our application but they never responded.
This is as far as I took my search. I solved the standby problem by leaving
it unplugged when I'm at home. These newer designs are smaller and more
effecient than the old ferroresonant guys but I didn't really find anything
that fit exactly what I needed so I stayed with the original. It would also
be nice to have a quick charge mode built in.
These Astron supplies are available used for under a $100 so if my supply
failed today I would probably put the Astron in the RV and use a high blower
relay for isolation if necessary. From the postings there are other
alternatives also but I don't know the relative costs.
Hope these ramblings help someone.
Dick
Another problem with these old ferroresonant chargers is they keep charging
your batteries until they are cooked as they don't cut back enough.
I would suggest checking marine stores before spending hard earned dollars
to buy outdated ferroresonant converters.
The boating industry threw them overboard awhile back and went to greatly
improved chargers which have a three modes of charging. They quickly charge
your battery until about 90% charged, then switch to a conventional charger
until 100 percent charged, then enter a float mode to supply no more than is
needed to keep them charged. This greatly extends battery life.
Some of the larger 120v inverters include this type of microprocessor
controlled charger when on shore power. One of them has a nice feature that
monitors total shore power current and automatically reduces the battery
charging current to keep from overloading shore power circuits while you use
other appliances.
Don
- -----Original Message-----
Date: Tuesday, August 04, 1998 14:02
Subject: Re: GMC: Converter recommendations?
>Ralph,
yours
price.
that
70
run
>surplus place.
supply
much
blower
>Dick
to
models I
folks
Ralph,
The old "buzz box" can be replaced easily with much improved units that
do everything better. I use TODD Industries converters, they come in
30, 40, & 45 amp. which works well in out application. They are solid
state units with cooling fans and very well regulated and standby
circuits, I would even go out on a linb and say I have not seen a
defective unit yet, but of course there are some somewhere. I have
found that most failures can be attributed to improper wiring or load
problems which should be completely checked out at installation.
I understand Cinnabar carries the 45 amp. in stock. I special order the
units for application. They run @ $155-250.
The old unit makes a pretty good crab trap anchor and in time will
convert to a coral reef! I do keep one in the shop as a back up battery
charger but I always have a volt meter to monitor its operation.
Hope this helps.
Jim Bounds www.gmccoop.com
