You will find that the vacuum operated valve in the hose to the heater
core does not positively shut off the flow of coolant. I've found that
the only time it is noticeable that heat is emanating (from the
defroster vents in my case) from the system is when the outside ambient
air temperature is > 80 degrees F.
I, and many others, have installed an additional, manually operated
positive shut-off valve in the heater hose at a point near the radiator
filler cap. An exact location near the radiator is not important, only
that you put it in the heater hose line (it can be either in the supply
(preferred one) or return lines). Do not put the valve assembly in
close proximity to the heater core metal tube connections, because the
hanging weight of the valve assembly is enough that in time, due to
vibrations while driving, it will case fatigue in the metal tubes and
cause them to crack. From the heater core toward the radiator, the
heater hose should be clamped to a support to isolate stress on the
heater core connection.
In my case, I installed a 1/2" brass ball valve, with hose barbs on
either end, to slide inside the heater hose cut that you must make to
install it. Use hose clamps to secure the valve assembly.
The ball valve has a short handle that pivots in a 90 degree arc between
the open and closed positions, so make sure installation does not impede
operation of the valve.
Installation is very easy to do.
The only inconvenience is having to manually turn the valve on or off.
Paul Bartz
> -----Original Message-----
> From: RickStapls [SMTP:RickStapls]
> Sent: Thursday, April 23, 1998 11:20 PM
> To: gmcmotorhome
> Subject: Re: GMC: Conversion to "FRIGC"
> In a message dated 4/23/98 2:32:14 PM MDT, crsalert
> They suggested putting in a separate heater hose valve as the
> mechanical one does not shut tight. .......
> Marcus:
> You should have a vacuum-operated water shut-off valve in your coach,
> located up front next to the heater assembly. It is actuated by the
> Grey vacuum line coming from the temperature valve vacuum port of your
> AC dash control unit. (See pp 1-104 thru 1-107 of your X-7525-A shop
> manual). The mechanical air flap in your heater is just to adjust the
> blend of hot and cold air. The vacuum valve is what shuts "off" the
> heat in the "recirc" position (which isn't necessarilly a
> "recirculating" position, but that's another story. ;-) ).
> On my coach, someone had removed and discarded the vacuum valve,
> probably on some cold winter's day when they were looking for heat! I
> found a likely- looking replacement at my local Carquest store (I
> think it was a CTC brand, part # 277804, if my records are right) I
> found the plugged-up vacuum line stuffed up beside the heater,
> reconnected it, and all was well again.
> PS: Is that Frig-C stuff EPA listed and approved? Let us know how it
> holds up for you.
> Rick Staples,
> Louisville, CO
