Connecting air tank behind front bumper
don w pontious
27
I am reinstalling the air tank on the frame rail behind the front bumper. I need to know where to put the pressure switch. Where does all the wiring come from and go to (from the fuse block to the pressure switch then the compressor)? Where are the wires located and possible color? I need to know the lay out between the air compressor to the red main air line that goes into the dash, including all the air fittings on the tank.
The coach is a 74 Sequioa.
The system was completely removed when I purchased the coach. I am only familiar with the Electro Level I system.
Thanks
Don
Free web-based email, Forever, From anywhere!
http://www.mailexcite.com
Thanks
Don
Thanks
Don
I think you are making a big mistake putting it behind the from bumper
unless you are talking about inside front end ot the right of the front
tire. The information that you need is located in the service manual for
the coach and you can buy it at Cinnabar Mfg.
>Thanks
>Don
