coach Vacuum system
Not to rain on your parade, but the OEM vacuum is a weak example of a
vacuum cleaner. A hand held dust buster type is far superior to it. I
removed the one in our 78 Royale and use a battery powered one from Home
Depot. But, to each, his own.
78 GMC ROYALE 403
On Mon, Mar 25, 2019, 7:08 AM CHARLES WOOD via Gmclist <
> can someone with the vacuum system inside take two measurements for me?1.
> from wall to center of outlet 2. from floor up to center of outlet. need to
> install it in mine.
> thanksCBW
Hi, Charles.
1) 17 5/8"
2) 16 3/8"
You are welcome to remove the outlet from my coach and retrieve the on-board vacuum you gave me some months back. I do not intend to install the system. I have a small Red Devil vacuum with power beater brush for carpets that I bought several years ago that stores in the compartment under the fridge.
D C "Mac" Macdonald​
Amateur Radio K2GKK​
Since 30 November '53​
USAF and FAA, Retired​
Member GMCMI & Classics​
Oklahoma City, OK​
"The Money Pit"​
TZE166V101966​
'76 ex-Palm Beach​
k2gkk + hotmail dot com​
Cell: 405-642-7337​
From: Gmclist on behalf of CHARLES WOOD via Gmclist
Sent: Monday, March 25, 2019 09:07
Cc: CHARLES WOOD
Subject: [GMCnet] coach Vacuum system
can someone with the vacuum system inside take two measurements for me?1. from wall to center of outlet 2. from floor up to center of outlet. need to install it in mine.
thanks
CBW
The 17 5/8" measurement is from the outer edge of the panel.
Mac
From: Gmclist on behalf of D C _Mac_ Macdonald via Gmclist
Sent: Monday, March 25, 2019 09:32
To: gmclist; GMC Wood, Charles
Cc: D C _Mac_ Macdonald
Subject: Re: [GMCnet] coach Vacuum system
Hi, Charles.
1) 17 5/8"
2) 16 3/8"
Oklahoma City, OK​
"The Money Pit"​
TZE166V101966​
'76 ex-Palm Beach​
Cell: 405-642-7337​
Cc: CHARLES WOOD
thanks
CBW
https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Flist.gmcnet.org%2Fmailman%2Flistinfo%2Fgmclist_list.gmcnet.org&data=02%7C01%7C%7C880c43599e6047b3949d08d6b12ed310%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636891211993927614&sdata=Im7GE%2F%2B8H9bxymg1r0jqVmjIB2OeQNcZ568BQhjmXqQ%3D&reserved=0
I find it has pretty good power. I'm away from coach now but can confirm any measurements later in the day.
Go back and read my reply on March 15.
I said: “The center of the hose connection/ switch on the face of the panel is 17” from the floor and 15-3/8” from the face of the cabinet.
The vacuum cabinet is mounted inside the cupboard opposite the hose connection. “
I sometimes feel people don’t read my messages.
Frederick, CO
I am with Jim H and others on this. We removed that weak and leaky stock vac from both of our GMCs and used a Dyson battery operated vac with a small power head instead. That was/is so much better that we now use that same unit in our Prevost. The small power head is ideal for reaching into all the small nooks and crannies in a motorhome. No need to buy the latest model as every one from a model six and forward have plenty of run time to do a good job in your motorhome on a single charge. Mount the charger/wall hanger in the back of the closet and it will be well out of the way.
Jerry Work
Kerby, OR
Any idea if that Dyson works better than the Dirt Devil Central vac
that's a direct replacement for the GMC OEM vac?
ronC
On Mon, 25 Mar 2019 12:00:47 -0700 Gerald Work via Gmclist
> Jerry Work
> Kerby, OR
Ron & Linda Clark
North Plains, ORYGUN
1978 Eleganza II
The unit has enough suction. It lacks a powered brush head. You can upgrade to a turbo type carpet head. Or go all out and put a modern port in with
added 125VAC power and buy an "electric" hose with powered head. I have this type setup at home. On the wand the low volt switch turns on the vac at
the first detent, then moving it to the second detent turns on the brush headas well. . Added benefit is on/offf at your thumb instead of having to
unplug the hose to pause.
ronC
