Made the voyage home on Sunday with the assistance of Wally Anderson. Can't say thanks enough to Wally or to Gary Mau, couldn't have made the the trip
without their generosity.
Torqued the lug nuts after the wheel swap last weekend, and had vacuum hose and a new trans modulator valve with us due to the seller's description of
how it last shifted. Got away with just the hose, found several cracks in the hose to the manifold. The modulator will go into the spare parts bin.
Due to the fuel in the tank being about 6 years old, used a boat tank with a hose to the fuel pump just to get it home. Wire tied the hose up under
the cab floor and routed it through the passenger's window, with a metal fuel filter joining the hoses in the wheel well. Set the tank on the floor in
front of the passenger seat so I could see the fuel level, 6 gallons doesn't last long! Replaced the pump to carb line as the original was leaking at
the fuel pump. Once that was in, no more leaks.
Took a good look over of the repairs so far, checked for any loose bits, and got ready to go. Brought 2 batteries, but didn't connect the coach
battery. Had already bypassed the isolator because the charge light was lit once it was running, figured 2 batteries would be enough to make the 115
mile trip even without it charging. Slapped a pair of 1974 vintage plates on it and off we went, Wally following behind to watch for trouble. Engine
sounded good, trans shifted great. The seller had said it didn't want to shift into top gear last time they used it, I suspect that leaky vacuum hose
was the culprit.
Made it about 20 miles, and the engine stalled. Topped up the boat tank from one of several gas cans we brought along, and set back out. Stalled again
after maybe a mile. Checked for fuel, and nothing at the carb. A squirt of carb cleaner would start it, so everything else was working. Long story
short, bypassed the metal filter in the wheel well, raised the boat tank to sit on the passenger's seat, and removed the filter in the carb. Plan on
cutting the carb filter open to check it out later today.
The rest of the way was trouble free. Made another fuel stop, refilled the boat tank and filled up one of the gas cans to have as a backup. The coach
cleared the hump in the driveway, I was a little concerned that it might drag but not a problem.
So finally it's where I can work on it without a 4 hour round trip. There's plenty to do, so we'll see how far I can get before the weather gets
nasty. Huge thanks to everybody that's given advice, and again to Wally and Gary!
John in Omaha, Nebraska
74 26' Sequoia
was the culprit.
74 26' Sequoia
