I have read a lot on this forum about cleaning and coating the inside and outside of fuel tanks. I am dropping my tanks this weekend and plan to
clean and coat them. When I was searching the older posts and did some searches I found a couple of suggestions. I can not locate one post that
connected to a video of an aircraft tank coating but I was able to locate two others. Red-Kote and POR15. Having never coated fuel tanks before I
was looking for direction. EASY is good BUT GOOD is better than easy and bad. My tanks do not look bad from underneath but I need to remove them to
do the fuel lines and while they are out a little (or a lot) of preventative maintenance would be good. Any advice or video links are greatly
appreciated.
Thank You
Melbo
appreciated.
Thank You
Melbo
