Cinnabar 3.42 final drive
john wright
1,064
Tom,
I watched the guys at buskirks install my 3:55 in about an hour and 45 min..
> Has anyone installed a cinnabar 3.42 final drive yet? I have some questions
> as I have never taken just a final drive out.
> 1. Does the cover have to be removed and fluid drained before pulling the
> 3.07 to get clearance to drop it?
As I remember they did not drain the fluid to remove the final drive.
> 2. What did you use to carry the weight of the final drive while removing it
> and reinstalling the new one?
They used a floor jack to slide the drive up into place.
> 3. CAn the new final drive be installed with the cover on? Cant remember is
> the 3.42 comes filled or not?
Leave the cover on, does not interfear with any thing and beside you do
not want to get dirt into the gear case. My guess is it does not have
any fluid in it an you need to fill and check the level when you get it installed.
> 4. Any tricks to doing it easier? I know emory suggested using longer bolts
> in the two bottom holes to make it mate easier.
Don't forget to remove AND reinstall the bolt that holds the short shaft
into the final drive. Forget to put it back in and you will shortly
destroy the final drive.
> thanks for the help I need to get this thing done by end of tomorrow to get
> on the road thursday.
> tom
J.R. Wright
GMC GreatLakers
Michigan
Most replacement drives do not come with the short shaft already installed.
John
> JR I am a little confused. what do you mean remove and replace the bolt in
> the short shaft? What is the reason for this? The short shaft is already
> installed on the new Cinnabar final drive as it comes from them.
> Thanks
> tom
> >Tom,
> installed.
> >> tom
> >J.R. Wright
> >GMC GreatLakers
> >77 Eleganza II
> >Michigan
J.R. Wright
GMC GreatLakers
Michigan
