Cherry Toro Engine F/S
jay honeycutt
27
Folks,
I don't know much about the GMC/s other than:
1. I like the 4 or 5 that I have checked out in the last
two years
2. They use Toronado running gear
Perhaps someone on the list can make better use of my
engine than can I.
My Toro is a '66 with a documented 64,000 miles. When
I first bought it, I had some valve guides and rocker arms
replaced. Later, I had all of the A/C checked out and the
? valve, condenser and drier replaced.
It runs beautifully, and the interior is almost new. BUT, the
body has bad rust in the lower subframe and I don't want
to trust a patch job.
My thinking is that a strong motor, that the buyer can hear
and try out should be worth $1200-1500 and that the parts
off of the car should warrant a total tab of $2,000.
Anyone interested - either in buying it or suggesting someone
who might?
The car is in St. Simons Island, Georgia, midway between
Savannah and Jacksonville, Florida.
Jay Honeycutt
- -----Original Message-----
To: gmcmotorhome
Date: Friday, February 04, 2000 5:06 PM
Subject: Re: GMC: Engine compartment vents
>pictures on several coaches from links off the net, but I don't remember
>suppliers or a good, proven source.
>Paul - I bought some from TC Camper in Calif. (NE of San Francisco.) I see
>that Caspro (AJ-USA) 1-800-877-1911 has them in their catalog for $59.00
per
>pair. They come with templates. Other suppliers probably have them too.
>Check Jim Bounds 1-888-275-4462.
>When I installed mine I drilled holes at each corner and then used a hand
>keyhole saw to cut out the fiberglass. This gave less chance of damaging
the
>surrounding paint than an electric saber saw would.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
