Check your Lower A arm ball joints
LarryW
6,039
764
113
Menomonie, WI.
The Greater Midwest Classics had a "work" rally at Steve Rasmussen's place last weekend. As one the workers, I was charged with checking the lower A
arm ball joints of every coach that was put on either of the two racks. Not necessarily checking for a bad joint, but rather checking for replacement
ball joints that were improperly installed or loose. The original ball joints were riveted in place, and according to the manual, (GMC Motorhome
Maintenance Manual X-7725) on page 3A-17 under "Ball Joint Checks", a pry bar is used to check for play. The "reading must not exceed .125". That is
1/8th inch. Unfortunately most alignment shops will check for play and to them any play at all is unacceptable, so they charge you for, and replace
ball joints that don't need replacement. Consequently there are many coaches out there with new lower ball joints that have been replaced using the
grade 8...5/16" bolts that come in the package. These new ball joints are held in place with three bolts. One larger bolt that goes down from the
top through the A frame into the ball joint. In addition then, there are two 5/16", bolts on the "Ears" of the joint. Considering that these joints
are really replacement for the Toronado or Eldorado, the 5/16" bolts are inadequate for this application. Over time these bolts come loose and can
lead to lower arm failure in cracks that can appear around the larger bolt hole or can loosen to the point of falling out, which can eventually lead
to a cocking of the joint which changes the camber and can wear out tires in a hurry. If you have replacement joints, the top larger bolt should be
checked first for tightness. Then the 5/16" bolts should come out and be replaced with 3/8" X 1 1/4" grade 8 international fine button bolts and you
should apply several drops of red Lock Tight to the threads. When drilling out the hole for the larger bolts, use progressively larger drills or
reams, until the bolt has a lightly snug fit in the hole. Of the 15 coaches that I checked, EVERY ONE of the lower arm ball joints were loose, and in
several cases, bolts on the ears were missing. Even two of the four ear bolts on mine were loose, and I had the 3/8" bolts in place, but without the
Lock Tight.
With that kind of a record, everyone should be checking the the bolts on their lower ball joints NOW. JMHO and HTH someone.
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Larry,
Steve Ferguson recommended the same thing.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Larry
Sent: Sunday, August 13, 2017 5:07 AM
Subject: [GMCnet] Check your Lower A arm ball joints
(GMC Motorhome
for, and replace
replaced using the
goes down from the
that these joints
loose and can
eventually lead
larger drills or
were loose, and in
Lock Tight.
Larry
Menomonie, WI.
Larry,
I say every time you change Oil is a good time to snug the bolts and the
nut.
We see that quite frequently at our shop.
Once the arm is gouged out, one should replace the arm.
> replacement
> the
> and in
> Lock Tight.
> Larry
> Menomonie, WI.
One more good reason for going to the 1-Ton, especially if you find the
lower A-arms damaged. That entire section is cut off and replaced with
much more robust material and better secured ball joints.
JMHO,
> were loose, and in
> Lock Tight.
> JMHO,
> Ken H.
May be a good reason to go to the one ton...but for now, checking and keeping those bolts tight will keep you safely on the road for some time to
come. JMHO
Larry
Menomonie, WI.
Larry,
If you replace the 5/16" bolts with 3/8" UNF bolts, apply red Locktite; and torque them to the max allowable they won't loosen, at
least the ones in Double Trouble's lower control arms I got from Steve Ferguson haven't since 2008!
Sydney, Australia
Sent: Sunday, August 13, 2017 1:46 PM
Subject: Re: [GMCnet] Check your Lower A arm ball joints
some time to come. JMHO
Larry
