The Statpower true charge does not acts as a converter. It will keep the
batteries charged as you use twelve volt power in the coach while you
are plugged in to shore power. A converter will change 120v energy into
12v energy thus bypassing your batteries. If you are using more 12v
power than the converter can produce you will be using your battery
reserves. Only when you do not use the excess power does the
converter/charger charge the batteries. Most converters have a battery
charger built in to them but it does not charge them in a battery
friendly way. Darren
Darren Paget
76 Experimental
Another Fab Day
http://www.TZEplus.com
Darren Paget
76 Experimental
Another Fab Day
