I am getting ready to drop the tranny pan to change the filter and replace the fluid in the pan.
Question: will the tranny drain more oil with the transmission cold or hot? Seems I've read somewhere that if the tranny is cold, fluid will drain
from the torque converter. So should I change the tranny fluid with a hot tranny or cold tranny to change the maximum amount of tranny fluid?
Thanks, Scott.
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi. Alex Ferrera
installed MSD Atomic EFI
Houston, Texas
Thanks, Scott.
Scott Nutter
Houston, Texas
