Change to electical choke
thomas g. warner
1,863
has anyone changed the 455 automatic choke to an electical one? I have my
old one torn apartl and it is rusted thru at the manifold. Guess I could
bend up a new one, but thought it might be better to change it to electric now.
I had some carb work done at The Carb Shop and they put on an electric
choke. Works great. They should be an easy install. If you have
any questions I can take a look at mikne and give you some info.
Scott Woodward would probably be able to give you some good info.
Marcus
Thomas:
I assume you are talking about the heat pick-up tube that bolts to the
intake manifold.
Cinnabar has new ones for not much money.
Replaced mine at time carburetor was overhauled..
Paul Bartz
> -----Original Message-----
> From: Thomas G. Warner [SMTP:warner]
> Sent: Saturday, April 11, 1998 5:43 PM
> To: gmcmotorhome
> Subject: GMC: Change to electical choke
> Has anyone changed the 455 automatic choke to an electical one?
> I have my old one torn apart and it is rusted thru at the manifold.
> Guess I could bend up a new one, but thought it might be better to
