certification for LP tanks
darren paget
1,553
That is why all fill hoses are either approved or not used from the installer.
There are proper hoses to use and improper hoses to use.
An installer of propane vessels will use the correct hoses. This is not part of
the certification process as it is done separately. If you choose to install it
yourself use proper hoses. Darren
> I think you will find that the certification is no longer valid when the
> fill and other controls are extended or changed from the manufacturer. The
> certified tank comes with the controls already installed.
> >I like it. I assume that you would use a stock tank and provide the
> >connections/bracketing. That should help ease the certification process.
> >I think that when my lottery check comes in, I will sign it over to you to
> >get all the great stuff you have developed.
> >Ron and Julie
> >73 Painted Desert
> >> It could be a lot cheaper if you were interested in only a single tank.
> >> 6 x 50 ~35 usable liters Darren
> >> > In a message dated 4/6/2000 11:00:31 AM Central Daylight Time,
> >> > >> > storage locker.
> >> > What do you think? Darren
> >> > I like it ('cept the $$)
> >> > Lanier
> >> > Jackson, MS
> >> > '73 GMC Excalibur
> >> > '29 Mercedes SSK Toad
> >> > '94 Tracker Toad
> >> > Reality Check:::::
> >> > There's no free lunch;
> >> > You get what you pay for;
> >> > And Nothing's gonna come in the mail !!
> >> > So, Go Back To Work !!!
> >> Darren Paget
> >> 76 Experimental
> >> Another Fab Day
> >> http://www.TZEplus.com
Darren Paget
76 Experimental
Another Fab Day
