Forgot to say that I still have the set of steel parts with the snap on cov=
ers to hold the ceiling panels in place. An owner had requested that I but=
this from a fellow GMCer and bring it to him at a rally. I bought the set=
for $10 and hauled it to the rally only to be told by the other GMcer that=
he decided that he didn=E2=80=99t need it. I still have it and would =
like to get my $10 back. If anyone needs it let me know. Emery Stora=
77 Kingsley Frederick, CO > Begin forwarded message: > > Fro=
m: Emery Stora > Subject: Re: [GMCnet] Ceiling Panel=
Molding > Date: December 25, 2016 at 2:36:50 PM MST > To: gmclist=
gmcnet.org > Cc: behrns70 > > >> On Dec 25, 2016, at 1=
:00 PM, Kym Behrns wrote:=
>> >> This is great info but I am also looking for the side mouldings=
that runs along the top of the walls. The PO remove them to do Renos and a=
re missing. >> >> Thx >> Kym >> -- > > I had written a parag=
raph in the GMC Motorhomes International motorhome club Fall 2004 newslette=
r that is as follows: > ------------- > INSIDE TRIM BETWEEN CEILING AND=
WALLS > Many have had problems with cracked trim that covers the cable t=
ray between the ceiling panels and the wall panels. The width of this trac=
k is approx. 3 inches. A member has found that the cover supplied with a "=
Panduit" electrical wiring tray has an "L" shaped edge that will jsut snap =
over the edge of the aluminum rails on the GMC cable tray at the top of the=
walls. It is made from white PVC and also comes in other colors or may be=
painted or covered with fabric. Part No. C3WH6 Panduit Tray Cover comes i=
n 6 foot lengths. The web site is:
http://www.panduit.com/ . Do a parts search on "C3WH6" and you can see the picture and =
cut sheets. The GMC rails measure 18 feet each, so you need a box of 6 cov=
ers to do the job. If you jsut need to do the small section over the door,=
try a local electrical supply house. When in place, the cover fits very t=
ightly and curves slightly concave. You will probably have to start a corn=
er and then use a wooden block and a hammer to snap it over the edges of yo=
ur GMC rails. If you want to finish the cover in some other cover, or a fa=
bric, you should do so before final attachment. > =E2=80=94=E2=80=94=
=E2=80=94=E2=80=94=E2=80=94=E2=80=94=E2=80=94=E2=80=94=E2=80=94=E2=80=94 =
> > Some have reported that it is too small and they could not get it to=
fit. > > My cable tray measures 3-3/16" with a caliper straight acros=
s the corners of the tray. Probably the same as what some have called a 3.=
25" tray. If you lay a tape measure across it the measure will bow a littl=
e and measure 3.25". The Panduit cover is 3-1/4" on the outside edges. I =
bought the Panduit tray cover through a large local electrical supply compa=
ny when I lived in Santa Fe. I just checked the Panduit site listed above =
and they still make it with the same part number. > > When I installed=
it on my GMC I found that I could hook the top of the cover over the top e=
dge of the cable tray and then while pushing down on the top of the cover t=
o bow the edge a little I could tap the bottom edge with a hammer and block=
of wood and get the cover to stretch a little so the the bottom edge would=
bow out and snap onto the lower edge. It would probably help if you spray=
the area with some silicone spray before installing. With it installed th=
e top and bottom of the cover are at a small angle to the face (i.e. greate=
r than 90 degrees at the edge). But it looks great. > It would probably =
be difficult to take it off once its installed but looks like it was made t=
o go there. The original was about impossible to remove without breaking i=
t off. > > Emery Stora > 77 Kingsley > Frederick, CO
