Hi
I see my friend Al Chernoff is asking about Cat Heaters, so maybe this will
help--The literature I have is not right up to date but is as follows:
Model 6P12A is 6000BTU's input
- - Draws less than .5 amps and weighs 15 lbs.
- -Heats up to 175 square feet ( Depending on insulation)
- -uses a thermostat
- -exterior venting is 1.5 ins. in size
- -Power venting removes 100% of combustion by products and replaces
combustion oxygen automatically.Automatic safety shut down in case of
malfunction
- -heats by radiation
Smaller model is 3P12A and is similar except is 3000BTU input and heats up
to 100 square feet of space. Also they surface mount or are 2.25 in
recessed. I saw one mounted on the left wall as you enter the coach and it
was hinged so it could be swung out at least 90 degrees.
Hope this helps .They may have new model numbers now . Don't know.
Claude B.
malfunction
Claude B.
