Snappy:
As Arch mentioned in an earlier response, Caspro is the only source for the
Power Drive, the only transmission modified system type available for us
that changes the effective gear ratio. However, in case you were not aware,
there are several other ring and pinion gear sets available (i. e. 3.21,
3.42, 3.55, and 3.67:1) for the differential.
Paul Bartz
Sent: Sunday, October 10, 1999 9:01 PM
I have to pull my trans to seal a leak. I pull a 7000lbs car trailer. I
would like comments on pros and cons of this conversion verses a gear
change.Is Casro the only source for these gears?
Paul Bartz
