Carburetor
something went wrong with the rebuild of the carburetor in order to throw up those numbers, so I acquired another carburetor, and installed it and
took it up there and it has some minor issues with 500+ HC when at low idle under 1100 rpm , but at 1100+ idle it PASSED with flying colors (62 HC),
still need to tweak the fuel mixture and as I had it extra lean(only 1 turn out on the mixture screws), the engine had no power to it at that point,
and I need to replace the automatic choke as the rivets are falling out of it.
David Morrison
P.S. hopefully California will pass sb-1239 for pre-1981 exception.
78 Royal #749
74 #136
Oversteer is when you hit the wall with the rear of the car, understeer is when you hit the wall with the front of the car. Hp is how fast you hit the
wall, and torque is how far you take the wall with you when you hit it.
I hope it passes too and they go back to the rolling 25 year exempt. So lame
Tony Cook
77' Kingsley ' SuperSession 77 '
Torrance Beach,CA
I feel the state will not roll back.
Once you have things running like it should, you'll find that the smog test
will not be a problem.
> lame
> Tony Cook
> Torrance Beach,CA
Applied/GMC, Fremont,CA
http://www.appliedgmc.com
