I can convert the front hubs to GMC 8-lug wheels
In the rear I have spindles on a heavy drop axle. The spindles are apparently quite unique and not compatable with any other, more common wheel/hub combinations.
So i'm exploring some alternative spindle, like from a GM one-ton.
But I don't understand offset.
The Revcon rims have some negative offset but not as much as the GMC as they are NOT dually rims. In the front some of the offset is countered by the wheel adapter that takes it from Toro 5-lug to a much bigger five lug. So, ultimately the front rims are close to being over the center of the hub face.
So, what would be the issues with the front end if you ran zero offset rims on a GMC? Assuming they lined up correctly with the rear wheels?
Dave & Ellen Silva
Check out the website:
http://www.oldrv.net
Dave & Ellen Silva
