Camera
gene
2,215
I am in, are they reverse ?? that is show the cars passing on the left ??
Does it come with connecting wire ??
do they have a web page
gene
>Those who are interested in just a camera with a video output that could
>be used on a tv with a video input or on a monitor with a video input.
>The camera can be purchased here from a company I know. The cm 600
>waterproof black and white camera ( little larger than 12 guage shotgun
>shell) and that costs $110 each. There is also a dome del e-100 E $115
>waterproof black and white.
>Both cameras are wide angle and are equiv to 2.8 mm lenses. Can see
>about 10 feet outward from your back. One rule of thumb is that they
>must be put high and pointed down. They should not face the sun as they
>will burn out. Color is great during the day, but at night the black and
>white better. Ultrk has a combination black and white and color both.
>Switches back and forth but it costs $700.
>Be careful that any camera that is mounted with a waterproof seal will
>have a lower life expectancy.
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
They are coming out with one in the next few weeks that allows you to set up
regular or reverse.
Will put more info when it comes in.
al
> gene
> mr.erf
FYI
I am sure that most of you know this but...
When buying a camera to use as a "rear view mirror", it
must be able to reverse the image. Or you must have a
monitor that is capable of that.
Your original rearview mirror is a reverse image. A
regular video camera and TV will give you a very
confusing point of view as a "rear view mirror".
You also need a camera with a fairly WIDE angle to be
able to see enough of the road (and toad) that is
behind you.
Just food for thought
Mike F
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of Al Chernoff
Sent: Tuesday, October 19, 1999 4:53 PM
To: gmcmotorhome
Subject: GMC: Camera
