Cam sprocket - plastic or not?
ken harland
292
1
Soon to be new owner asked if timing set had been changed and if not, was the cam sprocket plastic or not and I could not answer.
1978 Eleganza II
OE was nylon over aluminum cam gear. Heat and combustion by products attack the nylon over time. I’d be surprised to find a working survivor these
days but possible.
John Lebetski
Woodstock, IL
> I believe (well pretty sure) the OEM cam sprocket was nylon. Get a double roller chain and sprocket to replace it.
If he does get the double rolled, have him be sure to check that it is installed on time. The double roller are speed parts and so come with keyways
for +&-4°. He needs to know where he wants it to end up.
Not aluminum, It is steel. See below
Cloyes part no. is 9-3113
Summit part no. is MAH-9-3113
https://www.summitracing.com/parts/mah-93113
Jegs part no 220-9-3113
https://www.jegs.com/i/Cloyes/220/9-3113.010/10002/-1
On Ebay
https://tinyurl.com/537nxa84
https://tinyurl.com/w8nm2smh
https://tinyurl.com/94tksdn3
https://tinyurl.com/ybc54xst
https://tinyurl.com/yru97k9v
These are all from various Ebay suppliers
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> Thanks all, as I suspected, nylon over aluminum. I'll let him know.
> 1978 Eleganza II
The factory timing set has a nylon tipped steel cam gear. At least mine did.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
I second the mention using the Cloyes 9-3113 set (steel). We had our OEM nylon gear pulled a few years back by our mechanic, 65K miles on it, and the
nylon gear was pristine believe it or not. However our worry was like others mentioned, not knowing how much lift the nylon gear had left and didn't
want to worry about it.
Chris
Chris S. -
77 Kingsley, 3.70 FD, mostly OEM -
S.E. Michigan
At 67,000 miles, my gear looked good but the chain had stretched to the point that half of the crank gear teeth on the bottom were visible above the
chain.
Greg Crawford
KM4ZCR
Knoxville, TN
"Ruby Sue"
1977 Royale
Rear Bath
403 Engine
American Eagle Wheels
Early Version Alex Sirum Quad bags
Stock or plastic makes no difference. It's the combination of wear between
gears, sprockets, and chains that gives you the slack that RETARDS CAM
TIMING, the effect is that the torque curve is moved upwards in RPM'S.
If your 403 won't pull the hat off your head at 2200 rpm, but runs
like a scalded dog at 3600+ RPM'S, you probably have a stretched timing
chain. New double roller chain and sprockets, advanced 4° or so will wake
the lower rpm range up.
Salem, Oregon
On Fri, Jul 16, 2021, 3:58 PM Greg Crawford
> chain.
> Greg Crawford
> KM4ZCR
> Knoxville, TN
> "Ruby Sue"
> 1977 Royale
> Rear Bath
> 403 Engine
