Or read here
http://gmcws.org/blog/?p=4332
(Damm computers
> Read here
https://docs.google.com/viewerng/viewer?url=http://gmcws.org/blog/wp-content/uploads/GMC-presentation-FiTech-is-the-Real-Deal.pdf
> Most gmcws are busy at the rally
> On Sun, Apr 23, 2017 at 2:48 PM Skip Hartline
>> I like it,I got the 600hp because of the edlebrock top end I have. As I
>> was told don't expect better milage unless you were running super rich
>> before.
>> Mine learned itself in in a matter of a few minutes, the biggest problem
>> I've ran into is the throttle linkage is super stiff with the springs from
>> the factory they are right on the throttle shafts. I went on some camaro
>> forums and did what they suggested make sure and use the outermost hole and
>> release the spring on what I would call the secondaries but they really
>> aren't because all 4 open at the same time, then put you original springs or
>> some fron the "help" aisle at the auto parts store, you don't notice them
>> like you do the second spring fron the factory. My linkage wasn't exactly
>> stock so you might not have any issues. In the outermost linkage hole you
>> can't get full throttle plate opening but I don't think it would ever be
>> needed, at least for me it isn't. I'm using the fuel command center and
>> put it in the front of the right side of the radiator like another member of
>> the forum suggested, It was Gerald Work he did a whole presentation on
>> the install. You probably can search the forum or ask him directly for a
>> copy
>> of it. I can't seem to find it right now. Haven't got to try it out in
>> real vapor lock scenarios but it isn't suppose to do it at all, and all the
>> great cold starting the no hesitation acceleration and general overall
>> clean burning I've got now it is well worth it. Climb some small mountains
>> in
>> Georgia with a toad running only on 7 cylinders didn't even realize it
>> till I got back home and did some checking. Just my observations and ideals,
>> most of the ideals are by others but pride went out the window a few
>> years ago, remember "if there is a better ideal out there don't be to proud
>> to
>> use it, but be sure and give credit where credit id due"
>> Skip Hartline
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
> Gene Fisher -- 74-23,77PB/ore/ca
> “Give a man a fish; you have fed him for today --- give him a URL and
> Alternator Protection Cable
