I cannot remember as to which rocker I have been running in my 540 Cad for
over 600,000 miles on the Tube shaft since 1992, but I have never had any
problems since I went with it.
> Rob,
> I've been out of contact because of a little health problem. But I did
> scroll down to check the other comments on
> those rocker arms. Nobody is aware of the real problem. When that EBay
> ad first appeared, several guys on the
> Cadillac Forum said "Beware, that outfit has a reputation fore half-assed
> engineering and letting the customers
> sort out the fixes. They also changed their name recently to avoid the
> bad press". For instance, do you see
> anything that would preclude the pedestals from rotating?
> If you purchase a shaft rocker system, make sure of the ratio. They
> didn't have correct rockers for the Cad initially,
> so they used something made for a Buick or "?". There are a lot of those
> systems still floating around. Also, on a
> lot of those shaft systems the end rocker, which is only supported on one
> side, would break the shaft. I have to
> think that this might be a result of too thin a wall on the shaft and too
> stiff valve springs. Regardless, they then
> developed girdles to go over the top which stopped that problem. This, of
> course, required tall valve covers.
> I realize this is a little tedious, but I know you like to know all the
> parameters of a situation.
> Gary Kosier
> 77PB w/500Cad
> Newark, Ohio
> From: "Rob Mueller"
> Sent: Sunday, September 11, 2016 9:12 PM
> To:
> Subject: [GMCnet] Caddy 500 Rocker Arms
> G'day,
http://www.ebay.com.au/itm/291809956418?_trksid=p2060353.m14
>> 38.l2649&ssPageName=STRK%3AMEBIDX%3AIT
>> Comments?
>> Regards,
>> Rob M.
>> USAussie - Downunder
>> AUS '75 Avion - The Blue Streak TZE365V100428
>> USA '75 Avion - Double Trouble TZE365V100426
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
Applied/GMC, Fremont,CA
http://www.appliedgmc.com
