The deteriorated insulation on the boost cable was not in a RECALL.
It is mentioned in a DEALER SERVICE BULLETIN,
NUMBER: 77-TM-4
GROUP: 12-Chassis
Electrical-2
DATE June, 1977
The difference is that a Recall is mandated by the government and the dealer is to repair or replace it at GM’s expense
and there would be no time limit on the service.
A Dealer Service Bulletin is suggested maintenance and the costs would be borne by the owner.
Emery Stora
77 Kingsley
Frederick, CO
> Samuel,
> The large "red coated" cable from the passenger side solenoid, across the
> front of the frame, and into the driver's side wall IS the "boost cable"
> (which is what I'll henceforth call it). It passes through holes in the
> aluminum wall structure and eventually connects to the "house junction
> block" which you've found behind the converter. It should NOT have voltage
> applied from the front of the coach unless the boost solenoid is either
> stuck closed or the cable's been mis-connected.
> The deteriorated insulation at the front of the boost cable was cause for a
> GMC recall which should have caused that to be covered with a corrugated
> insulation tube. The portion of the cable inside the driver's side wall is
> generally, but not always, in good shape as it's protected from the
> elements. But the aluminum wall structure it passes through are tempting
> short points.
> You need to disconnect BOTH ends of that cable, at the front solenoid and
> the house junction block. Now use the Ohmmeter function of a multimeter to
> check for continuity between the cable and the coach metal ("ground" or
> "gnd"). If there's less than infinite resistance there, you MAY be lucky
> and locate the short along the exposed section of the cable and re-insulate
> it. But if the short is in the wall, your chances of finding it without
> completely gutting that side of the coach are slim -- replace the entire
> cable with a similarly sized one, well protected with an added cover, and
> carefully run and suspended inside the frame.
> That's probably enough "advice" for one note.
> Ken H.
> On Fri, Sep 20, 2019 at 10:03 PM Samuel Ferguson via Gmclist <
>> What is the large battery cable coming from the left side of the solenoid
>> on passenger firewall. I originally thought it was the booster cable. But I
>> have found today that the cable will have 12 volts to it from the engine
>> battery if hooked up. No voltage from House battery on it.
>> The cable runs down to frame area behind the front grill and runs to the
>> driver's side area and into the back firewall towards below the dash. Once
>> inside, I am unbale to locate the cable!
>> Samuel Ferguson
>> (Although I beginning to pull my hair out over this, I refuse to allow
>> electrical issues kick my butt!!!!!) 8o
>> Samuel Ferguson
>> Pittsfield, Illinois
>> (West Central Illinois)
>> 1976 GMC Palm Beach (A newbie who will not allow this thing to kick my
>> butt!!)
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
