Cab support failure
Matt Colie
11,101
807
113
South East Michigan near DTW
One of my cab supports has a broken leg.
Those of us that have spent a lot of time in the "engine room" of GMC know of the three legged support that goes from the cab floor to an isolator on
the frame. I had never noticed any problem here, but when pulling the front frame yesterday, I have found a problem. At that time the assembly was
rolling nicely, when I noticed something wrong. The A/C clutch had carried along an unrecognized piece of aluminum.
That piece was discovered to be one of the legs of the right side cab support. Quite specifically the one the leans into the engine space. It
appears to be a part of the welded aluminum structure. It also shows a lot of wear on the surface that was supposed to be a part of the cab floor
structure.
Plan to repair is undetermined at this time, but if anybody has any experience here, I would love to hear about it.
> If It's a clean break I would just TIG it back in and maybe add a gusset while I was there welding.
Justin,
As good an idea as that is, The coach is in my barn and I sold off the SigmArk years ago.
I could weld the bottom with my torch (yes, I did used to weld Al with an O2-C2H2 torch) but up against the plywood floor might not have a good
result. I know what I would have charged to do this as a traveling welder and that is why I am evaluating cold repairs intently.
With that repaired and a new body mount in place she should have that new car feel restored.
Matt,
Please explain what years this support design is on.
There are lot of people that will be looking for this when they have a
newer units. It is a good idea to inspect the newer ones with the formed
Aluminum mount.
On Thu, Feb 1, 2018 at 3:30 PM, John R. Lebetski
> car feel restored.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Jim,
I'm at the re-hab hospital twiddling my thumbs in between sessions with the physio terrorists working on my shoulder so I figgered
I'd give Matt a hand.
Reference Parts Book 78Z / Section 23 - Body / Page 23-2 / Figure 23-005 - Front Body, Cowl and Dash / Key 17 & 18.
Key: 17
P/N: 2001709
Description: SUPPORT ASSY - floor to body mounting RH (prior to Serial No. 6V100878) (repl. 698131)
Key: 18
P/N; 2001708
Description: SUPPORT ASSY - floor to body mounting LH (prior to Serial No. 6V100878) (repl. 698132)
Reference Maintenance Manual X-7525 / Section 2 - General Information / Page 1 / Figure 2 - Vehicle Identification Number
6 = 1976
V = Assembly Plant - Pontiac
100878 = Sequential Number
Therefore the "tripod" support was replaced with the formed support in 1976 starting with GMC S/N 100878.
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Jim Kanomata
Sent: Friday, February 2, 2018 3:00 PM
Subject: Re: [GMCnet] Cab support failure
Matt,
Please explain what years this support design is on. There are lot of people that will be looking for this when they have a newer
units. It is a good idea to inspect the newer ones with the formed Aluminum mount.
Rob,
Hope your going to be able to esape from there.
Take care, and thank you for your complete explanaton.
> Jim,
> Key: 17
> P/N: 2001709
> Key: 18
> P/N; 2001708
> 6 = 1976
> Regards,
> Rob M.
> Sydney, Australia
> Kanomata
> To: gmclist
> Matt,
> Aluminum mount.
> Jim Kanomata
> jimk
> 1-800-752-7502
Gotcha,
If that were the case (having not seen the break) I would probably use a structural epoxy (jb weld or better) and then attach a spanner plate across
the repair and rivet or bolt it in place.
No risk of burning down he coach and it would be plenty strong.
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
Matt, I would consider welding a properly shaped gusset to the bar while
off the coach, and the fastening the gusset to the aluminum cockpit frame
with screws. I used splice plates held with high-strength self-driving
screws to attach the rear body tub when I replaced the Adobe Posterior.
Then you can weld the lower point, which would be harder to fasten with
screwed connections.
Rick “who usually seeks the no-welding solution” Denney
> Justin,
> SigmArk years ago.
> Matt
Rick Denney
73 x-Glacier 230 "Jaws"
Drive it to a welder and spend the money to have it welded with an aluminum
wire feed. Probably charge you the minimum labor charge of $50-$100. Tig
welding probably not the best platform considering access/ cleanliness.
Sully
77 eleganza 2
Bellevue
> gusset
> > Justin,
> > SigmArk years ago.
> welder
> > Matt
> Rick Denney
