buzzer when I put it in drive
LQQKatJon
3,213
530
113
St. Cloud, Mn
lqqkatjon.blogspot.com
I was searching, and I can't find much....
there is a buzzer that when I put it in drive, buzzes, goes off. at least that is what it used to do, and what I think it is supposed to do. from
what i can read, maybe it is the buzzer to make sure I set air to travel??
prior to my new transmission, it generally went off when I selected D, and was not a problem. it would buzz occasionally when I Drove, but generally
pushing forward on the gear shift lever always shut it off. was not a bother.
Now with my new transmitter, if I had a pistol in hand, I think I would of shot the dash up trying to shut that sucker off. I have adjusted my shift
linkage multiple times, and I thought I had the problem solved a few times, but I was wrong. Last adjustment, it seemed fine for about 9 hours,
but then on my way to our rally, evertime I hit a big bump, it would start buzzing and I would have to push forward on the shifter to shut it off, and
then next crack in the road it would come on. sometimes leave it buzz for 10 seconds and it would shut off.
eventually on the way home, I opened the windows and turned up the radio. It would not buzz constantly, just about when you are in the heaviest of
traffic and construction where you really should not be trying to figure the sweet spot on the shifter to where it shuts off without actually kicking
the transmission into neutral.
I really don't want to adjust my transmisson shifter linkage anymore, because even though that changed the way it seemed to work, I now have it
adjusted perfect for shifting points. at one point, it would not lock the parking pawl. so had to mess with it again.
so my quetsion is:
what causes that buzzer to come on(thinking maybe dirty connection or maybe bent connector point) and secondly where exactly is it. so I don't have
to tear the entire dash down trying to hunt that thing down. and third, if I do find it, is cutting the wire an option, or will that screw
something else up??? I don't need to be reminded of setting to travel, or anything else.
Jon Roche
75 palm beach
St. Cloud, MN
> so my quetsion is:
> have to tear the entire dash down trying to hunt that thing down. and third, if I do find it, is cutting the wire an option, or will that screw
Jon,
That buzzer with delay off is power by a set of contacts in the same switch unit as neutral safety switch and the back up lights. It is down on the
steering column not far from the ignition switch. Unfortunately, as I write this, I am not sure where it is relative to the big ignition switch. It
only has six terminals and that is a lot less than the other.
In the case that you just want to rip it out, that is the only thing it does is buzz for a short time. The delay relay and the buzzer are two separate
parts my relay was a 3 terminal affair in a clip and the buzzer was just hanging on the wires behind the instrument panel.
Found the bugger. Took top rear of dash off. It was easy to find. Silver canister buZzer. It has 3 wires? Top cover ripped off when trying to
unplug it.
Should be much more peaceful driving now.
I even put a label
On it incase a Future person or myself wonders why there is a connector laying in there.
Jon Roche
75 palm beach
St. Cloud, MN
mine still buzzes when I put it into drive and also lights the put system into travel. I like it
Sent: Monday, August 24, 2020 8:26 PM
Cc: Jon Roche
Subject: Re: [GMCnet] buzzer when I put it in drive
unplug it.
I even put a label
Jon Roche
75 palm beach
St. Cloud, MN
