Recently, someone asked if there was a buyer's checklist for used RV
purchases. I've got the start of one here, so take a read through it
and make any corrections and additions you deem necessary.
Buyer's Checklist for Use When Examining Any RV
There are at least six major areas to cover in your examination:
1) Engine and Drivetrain
2) Suspension and running gear
3) Exterior items and appearance (including potential roof and seam leaks)
4) RV Systems (including coach and vehicle controls and accessories)
5) Interior Items (cabinets, beds, seats, storage)
6) Maintenance records
If you haven't done anything like this before, some beginning advice is
warranted. First, you need to do this during the daylight hours when it is
not raining. Second, you are going to need an assistant. The assistant is
important for a couple of reasons: to record your observations and to make
observations on things you've overlooked.
Things you'll need during your examination:
1) Good flashlight. I prefer to carry a 6 volt lantern with a tilting
head and a pocket flashlight for peering into smaller darkened areas.
2) A clipboard to hold your checklist and notes. A few pencils (unless
you have a pen that writes upside-down and on greasy paper).
3) Rags to wipe-off your hands and anything else that gets dirty. White
rags, like diapers will make is very easy to see the condition of crankcase
fluids. Some waterless hand cleaner also goes a long way to keeping the
seller happy. Work gloves just in case the unit is hot. I almost always
carry latex examination gloves (like hospitals use) for their
convinience.
4) Coveralls. After crawling around under that rig, it is nice to be
able to remove your dirty clothing before getting back into your car.
5) Eye protection. Pulling on old exhaust systems is a recipe for eye
disaster unless you are wearing some sort of eye protection.
One other overriding idea to keep in mind is that you're looking for
evidence of regular maintenance and care. Don't worry too much about
"normal" maintenance items. For example, the tires or shocks may be old
or worn. These are typically replaced every five years or so. Don't be
too surprised if they need replacement. On the other hand, closely look at
the front suspension. If it is worn, the ball joints are leaking and out of
grease, your chances are pretty good that the previous owners deferred
critical maintenance and you may be in for other expensive surprises.
Areas of Inspection:
Engine - general condition & cleanliness
Carbeurator - cruddy looking & covered with deposits?
Exhaust Manifolds - look for cracked or warped stock manifolds
Ignition System (alternator, coil, spark plugs, wires, distributor)
Radiator including all hoses
Oil Cooler & lines should not leak and not be older than 5 years
Transmission Cooler & lines should not leak and not be older than 5 years
Transmission pan/fluid - any evidence of leakage?
Master Cylinder - positively must be perfect
Wheel bearings front and rear - check bearing runout with wheels off the
ground
CV Joints should be dry outside and well lubed inside
Belts - no checking or cracking
Fuel Lines - if spongy rubber, they're a problem
Fuel tank - no leaks or rust
Starting battery - full of distilled water and fully charged
Tire condition and inflation - check inflation and age of rubber
Wheel condition - split steel wheels are dangerous
Bogie pins lubed - check with seller - if he has no clue, they haven't
been Visually check alignment on both sides of coach
Exhaust system - holes and rust?
With Motor Running:
Check Transmission Oil Level - smell it. Burned fluid is bad
Check Power Steering Fluid - smell it also
Review all gauges and driver controls:
Oil Pressure
Oil Temperature
Voltage Meter/Ammeter
Water Temp
Fuel Level - all tanks
Airbag pressure
Accessory Warning Indicators
Tachometer
Vacuum level
Parking brake
Dash/instrument lighting (headlights on outside)
Dimmer for dash lights
High beam indicator (inside and outside)
Turn signal indicators (inside and outside)
Emergency flashers (inside and outside)
Parking lights (inside and outside)
Clearance lights (outside)
Compartment lights
Horn
Windshield wipers and washer
Panel A/C and Heater Controls - especially check A/C function
Defroster
Radio/Stereo
CB Radio
Driving Checks:
Speedometer and odometer
Cruise Control
Steering responsiveness
straight road
curves
rough roads
crowned roads
Brakes - normal and panic
Acceleration
Traction - especially uphill
Transmission shifting
Manually downshift & upshift
Passing gear
Exhaust noise
Shocks & Air Bag Condition
Wiper Blades' Condition
2) Suspension & Running Gear
Steering & Linkages should be tight
Brakes - examine brake linings and disks/drums on all wheels
examine steel lines running from master cylinder to all wheels
examine all flexible brake hoses
Wheel Bearings
CV Joints
Shock absorbers - no evidence of leakage
Bushings - cracked and distorted will need to be replaced
Ball Joints - check for play and recent grease
Brake Lines at wheels - look for soft hoses
Steel Brake Lines on coach frame
Coach frame (rust)
3) Exterior Items
Main entry door seal/lock
Windhield
Outside mirrors
Roll-down windows
Sliding windows (especially rubber at tracks)
Fixed windows
General paint condition
Bumpers (rust) chromed?
Steps
Access Doors (self supporting, flapping)
Ladder
Fresh water hookup
Electrical hookup
Generator - make and model
Generator Hours
Turn on Generator using Front/Rear switches
Generator Volt Meter Gauge
Generator Water Temp Gauge
Generator Hour Meter Gauge
Generator Oil Pressure Gauge
Extend & Retract Generator Drawer
Check Generator Oil at Dipstick
Check Power Line Monitors
Generator Battery Condition
Generator Service Manual
Spare tire and condition (same as others?)
Macerator type and function
Fuel filler & cap (check overflow hose)
Towing equipment
Antennas
Roof pods (evidence of overloading and leakage)
Roof air (specifically dents & evidence of leakage)
Fans (evidence of leakage)
Fresh water tanks
Grey water tank
Black water tank
Main and Window Awning(s)
Solar charging system
Jack functioning?
Fresh water hoses and water purifier included?
4) RV Systems
Refrigerator - brand, type and age
Microwave
Built-in appliances (coffee maker, blender, vacuum, etc.)
Range
Oven
Kitchen sink (check drains)
Ice maker
Television
Sound system
Exhaust fans
Air conditioning - brand, type, age and efficiency
Heater
Water heater
Water pump
Toilet (leaks, drains, etc.)
Bathroom sink
Shower (alert to water damage, hot water capacity)
System Monitor & Control Panels
Thermometer & Clock
Tank Monitors
Propane Monitor
Refrigerator Fan Switch
AC Power Selector Switch
House batteries
110 volt inverters
Sewer hose
Power lines (50 amp, 30 amp and 20 amp adapters)
5) Interior Items
Driver seat controls and comfort
Passenger seat controls and comfort
All seat belts intact
Auxiliary seating
Couch
Dining - how many can sit comfortably
A/C and D/C outlets functioning
Window screens
Interior lights
Access to storage
Doors latch
Drawers secure
Bedding fresh (mildew in mattress is impossible to remove)
Evidence of any water damage?
Roof line
Inside storage areas
Below grade (ie, under coach)
Bath and storage tank area
Seams at roof and sidewalls
Any delamination or evidence of water damage should scare you
6) Maintenance Records
Service or Repair logs
Major systems rebuilt
Owner's manuals for coach and all applicances
Mileage
Last Oil Change - type of oil
Last chassis lube
Last tuneup
Spare Filters:
Air
Oil
Any Spare Parts
Tires - brand and size
Previous owners
I've Appended the following excellent RV Data Sheet (from Mike Finnicum)
It may help to organize things for you!
Model Year:
Model:
Price: How firm:
Total Mileage: Can it be documented:
How long have you owned coach:
Location of coach:
Engine
CID (455 or 403):
Original (Y/N):
Overhauled:
If overhauled
Miles since overhaul:
How extensive:
Any warranty left:
Other major work done:
Current Condition:
Transmission/Final Drive
Original (Y/N):
Overhauled:
If overhauled
How extensive:
Any warranty left:
Final Gear Ratio (ie: 3.08, 3.46):
Current Condition:
Exterior
Colors:
Condition:
When last painted:
How extensive:
Photos available:
Tires
Year replaced:
Miles:
Brand:
Batteries
Front - Year replaced:
Rear - Year replaced:
Maint records
Are they available
Is there a cronology
How far back do they go
Interior
FloorPlan
Rear
Facing mini-couches: Table:
Queen Bed Fixed: Are orig mini-couches avail:
Twin Beds:
Other:
Front
Orig Couch/Bunkbed:
Orig Dinette w/table:
Orig Swivel Chairs w/table:
Other:
Driver
Orig Capt Chairs:
Other:
Upholstery
Colors:
Type fabric:
Condition (New, Perfect, Good, Fair, Needs replacing):
When last redone:
How extensive:
Are different fabrics/colors/textures
used for different items?
If so please explain:
Carpet
Colors:
Style (Berber, Plush, etc):
When last redone:
How extensive:
Blinds
Colors:
Style (curtains, miniblinds, other):
When last redone:
How extensive:
Refrigerator: 2way? or 3way(w/gas)?
When replaced:
Microwave?
Towing hitch?
Any damage?
Ever wrecked?
What does not work?
What needs attention?
Any special features, options, comments?
How stored? Inside: Outside:
Your Mileage experience?
Gary Thurlow
email to thurlow
St. Louis, MO
convinience.
ground
With Motor Running:
Oil Pressure
Oil Temperature
Water Temp
Airbag pressure
Tachometer
Vacuum level
Parking brake
Compartment lights
Horn
Defroster
Radio/Stereo
CB Radio
Driving Checks:
Cruise Control
straight road
curves
rough roads
crowned roads
Acceleration
Passing gear
Exhaust noise
Wheel Bearings
CV Joints
Coach frame (rust)
3) Exterior Items
Windhield
Outside mirrors
Roll-down windows
Fixed windows
Steps
Ladder
Fresh water hookup
Electrical hookup
Generator Hours
Towing equipment
Antennas
Fresh water tanks
Grey water tank
Black water tank
Jack functioning?
4) RV Systems
Microwave
Range
Oven
Ice maker
Television
Sound system
Exhaust fans
Heater
Water heater
Water pump
Bathroom sink
Thermometer & Clock
Tank Monitors
Propane Monitor
House batteries
110 volt inverters
Sewer hose
5) Interior Items
Auxiliary seating
Couch
Window screens
Interior lights
Access to storage
Doors latch
Drawers secure
Roof line
Mileage
Last chassis lube
Last tuneup
Spare Filters:
Air
Oil
Any Spare Parts
Previous owners
Model Year:
Model:
Price: How firm:
Location of coach:
Engine
CID (455 or 403):
Original (Y/N):
Overhauled:
If overhauled
How extensive:
Any warranty left:
Current Condition:
Original (Y/N):
Overhauled:
If overhauled
How extensive:
Any warranty left:
Current Condition:
Exterior
Colors:
Condition:
When last painted:
How extensive:
Photos available:
Tires
Year replaced:
Miles:
Brand:
Batteries
Maint records
Are they available
Interior
FloorPlan
Rear
Twin Beds:
Other:
Front
Orig Couch/Bunkbed:
Other:
Driver
Orig Capt Chairs:
Other:
Upholstery
Colors:
Type fabric:
When last redone:
How extensive:
Carpet
Colors:
When last redone:
How extensive:
Blinds
Colors:
When last redone:
How extensive:
When replaced:
Microwave?
Towing hitch?
Any damage?
Ever wrecked?
What does not work?
Gary Thurlow
email to thurlow
St. Louis, MO
