What Jim said. You need the belt hook brackets which bolt to the ceiling
framing and hide behind the headliner. Then you can make any belt set up
you want as long as the tang on the end of the belt will mate with the
ceiling hook.
Sully
Bellevue wa
On Fri, Nov 13, 2020 at 10:27 AM Jim Kanomata via Gmclist <
> Belt is not the issue, but the steel plater that connect to the ceiling
> latch.
> On Fri, Nov 13, 2020 at 9:01 AM Randy Hecht via Gmclist <
> > They are 32 inches long, 1 7/8 inch wide Seat belt webbing
> > > On Nov 13, 2020, at 10:18 AM, John Richardson via Gmclist <
> > > Any good auto upholstery shop can make them for you,but you need a
> > sample
> > > for them to
duplicate.maybe someone will take a picture of them and
> send
> > it
> > > to you.. good luck.
> > >> On Fri, Nov 13, 2020, 8:18 AM Mike Ballard via Gmclist <
> > >> The PO replaced the bunk bed support straps on our coach with chains,
> > and
> > >> I would like to go back to the original design. I haven't found any
> > source
> > >> for the straps from the usual places, are they available anywhere. I
> > >> haven't found any guidance on replacing with a seat belt type strap
> > either.
> > >> Mike & Apryl Ballard
> > >> Fair Play, Missouri
> > >> 1975 Glenbrook
> > >> _______________________________________________
> > >> GMCnet mailing list
> > >> Unsubscribe or Change List Options:
> > > GMCnet mailing list
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
http://www.gmcrvparts.com
> 1-800-752-7502
