To rule out front wheels and tires I would remove both of them and switch
with either of the rears. Mark them if you want to remember where you
started. If the bump stays unchanged with the wheel swap next spot to check
is probably the driveshafts as others have mentioned. Is it a noise or a
noise and a tugging in the wheel? Noise and tugging while turned likely a
driveshaft. Does the noise or bump change depending on whether you are
loaded or not? Try the same turning operation driving like normal then try
it in neutral while coasting and see what you get.
Sully
On Monday, October 17, 2016, Bill Van Vlack
wrote:
> > The "bump" could be a lot of things. Swapping wheels is a quick and easy
> > way to rule out a wheel or tire problem. I suspect as Ken mentioned a
> > driveshaft issue but the wheel swap might isolate a tire with belt
> damage.
> > Tires with belt or cord damage can have some strange symptoms.
> Forgot to mention, new Michelins and used wheels recently, FWIW. No bumps
> while moving wheel, just when holding to left; no bumps moving or holding to
> right that I've been able to feel. Swap DS or PS tires/wheels? Or both,
> one side at a time? Question is really which side is likely to have the
> problem given bumps only happen holding to left?
> Bill Van Vlack
> '76 Royale; Guemes Island, Washington; Twin bed, full (DS) side bath,
> Brazilian Redwood counter and settee tops,455, 6KW generator; new owner a/o
> mid
> November 2015; Since arrival: New HVAC blower, heat flap cable, headlight
> switch.
