Bullitthead re bath door repair
steve southworth
3,088
> almost stock interior, except for the bathroom door being removed for repair(which was a can of worms best left alone, even if it was damaged). In
> the carport now, so rain is not a factor in viewing it.
What problems are you having with the repair. Mine is getting loose where the door is bonded to the hinge.
Steve Southworth
Palmyra WI
Steve,
I had cosmetic damage from loose cargo that smashed a dent in the outside laminate. This door is made with an aluminum frame with the inside Formica
bonded (glued, no screws)to it, and a cardboard honeycomb bonded to the Formica to fill the inside of the door. Then another sheet of woodgrain
Formica is bonded to the cardboard and the frame. I'm sure it was all done on a large platen with hot sprayed glue and a press and then the outside
edges were machined perfect to the aluminum frame. 3 flimsy pieces and some cardboard and glue make something so strong you could use it as a bunk bed
for an adult. Got it apart now and can't find a glue to effectively bond the Formica chips back together.
My hinges are screwed to the aluminum frame, not bonded, so your construction must be different. Unless you are saying the frame has come unbonded
from the Formica panels, in which case you are in the same boat as me, needing a good glue to rebond the panels to aluminum or anything else.
Cyanoacrylate (superglue)does not work on naked broken Formica, wood glue worked better, everything else rubs off. GM had it years ago, but I'm sure
there was some equipment involved... looks like sprayed on red contact cement.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
I fixed mine with gorilla glue. Just make sure to clamp it well over night while it sets up as it will expand. If you use too much it will expand
out of the seam. It can be cleaned up easily with a razor blade. I usually trim it before it fully set up.
> Steve,
> Formica bonded (glued, no screws)to it, and a cardboard honeycomb bonded to the Formica to fill the inside of the door. Then another sheet of
> woodgrain Formica is bonded to the cardboard and the frame. I'm sure it was all done on a large platen with hot sprayed glue and a press and then
> the outside edges were machined perfect to the aluminum frame. 3 flimsy pieces and some cardboard and glue make something so strong you could use it
> as a bunk bed for an adult. Got it apart now and can't find a glue to effectively bond the Formica chips back together.
Terry,
You are right in that they were assembled with a spray adhesive. At least mine were.
When they delaminated, I put them back together with moistened Gorilla Glue (a single part moisture activated polyurethane). I was ready for it to
swell on cure, so I had it supported on some 2*6 as strongbacks and used about forty clamps (when my father and I built boats and spares we needed
lots) to hold it from swelling and puckering during curing. I could not use an epoxy as it needed to fill a number of gaps that were probably OE.
Both that and the hanging locker (closet) door are good now.
