Not high enough rotational speed to generate the heat needed to do a good job.
You should be able to rent the Milwaukee or something similar from a rental place
for about $25 - $30 for the weekend. The small ones you see at Sears etc. just
are not powerfull enough to do the proper job. Call if you have any questions.
716-271-1154.
A good buffing job is not hard to learn, but there are some tricks and things to
watch out for.
Marcus
> Marcus et al.
> Thanks for the post on minimizing elbow grease when trying to restore
> weathered etc exteriors. I am tool deprived so buying new ones is always an
> adventure, I do have a Bosch random orbital sander, fairly heavy duty, pretty
> sure I can get foam pads to fit it, is that appropriate to be used as a
> buffer?
> Thanks
> Chuck D
> Stillwater Mn
716-271-1154.
watch out for.
Marcus
> Marcus et al.
> buffer?
> Thanks
> Chuck D
> Stillwater Mn
