If you haven’t already seen this photo album then this is the ‘How Too” by Arch.
http://www.gmcmotorhome.com/commodore/front_brake/index.html
JR Wright
Michigan
> P x A
> Of course, I’m still hung up on measuring velocity in furlongs per fortnight.
> Dolph
> DE AD0LF
> Wheeling, West Virginia
> 1977 26’ ex-PalmBeach
> Howell EFI & EBL, Reaction Arms, Manny Transmission
> “The Aluminum and Fiberglass Mistress"
>> Ponder this. 100 psi line pressure applied to a caliper piston that has an
>> area of 2 square inches, versus 100 psi line pressure applied to a caliper
>> piston of 4 square inches.
>> Question? Which one has more stopping pressure? (Grin)
>> Jim Hupy
>> Salem, Oregon
>> On Sat, Nov 2, 2019, 8:52 AM Dolph Santorine via Gmclist <
>>> In the link sent by Ken, the Autozone reman calipers are mentioned.
>>> Check them before you leave the store. The cores get thrown into a crate
>>> during the process, and the holes on the ears for the bolts can be oblong.
>>> As in less than round. As in the bolt won’t go in there. You get it.
>>> The last thing you want to be doing with that casting is trying to bend
>>> (break?) them back out to put it all together.
>>> I learned that the hard way.
>>> BTW, I usually go to the “Red” Store (Advance), but since Dave Lenzi
>>> recommended that I use the AutoZone calipers, I used the Orange store.
>>> They are a better rebuild.
>>> Just say’in.
>>> Dolph
>>> DE AD0LF
>>>> On Nov 2, 2019, at 11:39 AM, Ken Henderson via Gmclist <
>>>> Johnny,
>>>> If you Google "GMCNet Archive" and then search for "80 mm calipers"
>>> you'll
>>>> get the last few years of related 'net traffic. Here's the most
>>> essential
>>>> information:
https://groups.google.com/forum/#!searchin/gmcnet-archive/80$20mm$20calipers%7Csort:date/gmcnet-archive/0IV4h8Yv1FI/iFJ0mULyAAAJ
>>>> As far as MC -- with everything else OEM, the MC will handle the 80mm OK.
>>>> There's one little bump on the outside of the 80 mm casting which can be
>>>> cut off very easily to clear the Alcoas. The OEM pads fit the 80 mm (I
>>>> strongly recommend Performance Friction 0052.20's).
>>>> Ken H.
>>>> On Sat, Nov 2, 2019 at 9:36 AM Johnny Bridges via Gmclist <
>>>>> Starting in redoing the brake hydraulic system, which isn't working
>>> well.
>>>>> I'm told 'Use the 80MM caliper'. Now, does this simply mean the 80MM
>>> had a
>>>>> bigger piston diameter (giving greater pressure to the pads) uses the
>>>>> stock disc or does this mean the disc has to swap as well? I realize
>>> the
>>>>> 80MM
>>>>> is going to need some massaging with my grinder to clear. I hafta
>>> choose
>>>>> before I go for new hoses.
>>>>> --johnny
>>>>> Foolish Carriage, 76 26' Eleganza(?) with beaucoup mods and add - ons.
>>>>> Braselton, Ga.
>>>>> I forgive them all, save those who hurt the dogs. They must answer to
>>> me
>>>>> in hell
>>>>> _______________________________________________
>>>>> GMCnet mailing list
>>>>> Unsubscribe or Change List Options:
>>>> GMCnet mailing list
>>> GMCnet mailing list
