If your brakes are adjusted correctly in the rear (drum) and the STARS
are operable. When you back up your brakes are self adjusting.
Whalla! Take Care Chuck. Not that I do no't envy your new DISC type.
If I could do that trick at this point I would only do the front two of
the four rear. The reason seems quite obvious to me but it may not to
some of you. The drum brake could still work as an emergency brake and
while the GMC is not very good here (rear brakes emergency) this might
be just enough to make it efficient. Chuck
