Brakes
jerry hoxsey
188
Here I am back with another problem. I AM back because I know this net is
the greatest source of info on a GMC there is!!!!!! Here it is; going down
a grade when applying light brake I get a vibration. Only happens when
brakes are applied. Bearings were repacked about 6000 miles ago and at same
time brakes checked by well known GMC shop. I was told brakes were FINE.
If I had to guess it feels like a warped rotor. Any ideas?
May take me a while to respond since I only get the digest.
Thanks,
Jerry
Jerry,
Sounds like warped rotor(s) to me. Where do you feel the vibration, in the
brake pedal and/or the steerig wheel?
Peter
Colorado
To: "GMC NET"
Sent: Sunday, January 16, 2000 3:12 PM
Subject: GMC: Brakes
down
same
> Thanks,
> Jerry
Two things
1. Wheel nuts put on with a impact wrench instead of a torque
wrench..Loosen each nut and than retorque using a good torque wrench. Never
never let anyone use an impact wrench on your wheels.
2. Contamination on your discs and.or rotorsd,,if so you can see it
>Jerry,
> Peter
>77 Eleganza II
>Colorado
>From: "Jerry Hoxsey"
>To: "GMC NET"
>down
>same
>> Thanks,
>> Jerry
