Has anyone ever installed a true proportioning valve?
My coach is stripped bare, and new floors installed. It will be a while before I start furnishing it. In the meantime, it's not very drivable because the rear wheels lock up super, stupid easily, It's also not very drivable because the rear wheel wells are out, but that problem is easy enough to solve...
I'd like an adjustable one, to keep up with the weight changes as the build progresses.
I also have an extremely fast idle that wasn't there before I had it smogged. I found one cap was pulled off a vacuum port but that didn't help. The brake makes a hissing sound too, and the cruise control hose is all bundled up and tied off under the floor. I don't know if that's normal or not. I also found a piece of foam insulation under the forward butterfly valve about the size of a marble. It starts pretty easily so I don't think there's any more debris? I'm pretty sure it got there when I had it smogged.
