Brake Pedal Slowly Goes To The Floor
Tom Katzenberger
795
287
63
Good Morning all,
My situation is as follows:
Components: I have installed my 3rd new P30 Master Cylinder on a new 6 Disc brake system. All lines have been replaced with stainless steel solid and
braded where needed. I installed a new combination valve which has the piston removed so it no longer proportions from front to rear. I have Dave
Lindsey's sensitized brake booster with a summit back up vacuum pump.
Problem: After bench bleeding and making sure the plunger is not depressed more than 1" I still have the the brake pedal slowly sinking while under
steady pressure.
I am looking for the wisdom of the members on this site. Again and as always, all opinions and thoughts are welcome and appreciated.
Thank you all.
Sincerely,
Tom K.
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D., Micro Level, Howell EBL-EFI Spark Control, Macerator, York Air Compressor, 6 Wheel Disc, Quadra Bag, Onan W/Bovee
Ignition
That sounds to me like an internal failure of your master cylinder.
An old time mechanic taught me this " New parts are just new, they
are not necessarily good or serviceable". I had a similar issue with a new
master cylinder, pedal creep. Turns out the fluid was bypassing the tandem
seal inside the cylinder. When I took it apart and inspected it, the bore
finish was eccentric. Bad machining. Junk. Bought a new OEM cylinder. All
was right in the brake world.
> Which 6 disc brake system are you using (rears)?
> Larry
> 78 Royale w/500 Caddy
> Menomonie, WI.
Dead head the system. Block off the master. If it holds move to to the combo valve. If it still holds work your way down the system .
Michael Orlandi
Fairfield, Ca
1973 GMC Canyonlands
Lenzi knuckles/ hubs
Tom, If you aren't losing fluid from the system, it is almost certainly a defective/damaged master cylinder. The classic test of a master cylinder
involves first "stabbing" the brake pedal (stepping on it hard and fast). This will often cause a worn piston cup to momentarily seal and hold
pressure. Then release the pedal and rest your foot lightly on it and slowly push down. A bad master will seep fluid back into the reservoir, and
the pedal will sink.
HTH
Rick Staples
I don't believe that stabbing the pedal works on the cursed P30 MC because it uses poppet valves rather than the piston cups you mentioned.
Christo Darsch
GMC Nor'easters
1977 Eleganza II - "The Komet"
3.50 Power Drive, Disc Brakes, Alcoas
Weymouth, MA
Guys,
That is also what I thought and was my experience in the past.
Rather then installing another P30, I am looking at the 2 stage master and the Hydro boost. The 2 stage master is the easiest and cheapest so I will
try that first.
I am really not interested in installing a 4th P30.
Take care and I will report back.
Thanks again guys,
Tom K.
Ignition
