seems like I have been tossing brake parts at my coach for years.... 9 years ago, I installed a sensitized booster bought at the time from the GMC
Coop. few years ago, I went and replaced all rear brake shoes, springs and cylinders and up'd the size of the mid axle wheel cylinder.
Last fall, I changed out stock calipers up front for the 80mm calipers, and installed perfomance friction brake pads. We used a special tool to
really prep up the rotors, and those Pads "bedded" in real fast and really well. I bet I had less then $150 in doing that change. (I had probably 8
year old stock front brakes).
So with a 9 year old sensitized brake booster, a stock master cylinder, 80mm front calipers running performance friction pads, the larger mid wheel
cylinder and stock rear brakes. I have no concern at all about stopping. I have been driving my coach almost as a daily driver this spring, and
stop/go traffic, around town and it stops just as well as my honda crv.
I have recently driven some coaches that have no "sensitized" booster, and have an old stock one in the coach. And they stop fine, but I really would
not want to drive them around town like I do my coach. and would not want to ever try to stop them without wearing shoes.
so in my opinion, running a sensitized booster, stock master cylinder, 80mm brakes(only if you need to change bad 70mm), and a mid axle larger
cylinder(again- only if you are changing brakes there). makes for a really pleasant driving/stopping experience.
Jon Roche
75 palm beach
St. Cloud, MN
Jon Roche
75 palm beach
St. Cloud, MN
