'brake' light on dash. what does it mean?
Matt Colie
11,101
807
113
South East Michigan near DTW
Charles,
It is installed to have two indications:
1 - Indicate that there is an imbalance between the front and rear brake circuits. (You lost a brake system.)
2 - Indicate that the parking brake lever is in the "set" position. This has a high failure rate.
I hope this help.
Matt..
Where is the actual switch that reports to the "PARK BRAKE" Tell-Tale display?
I see two brake switches on the electrical diagram... One is the "Differential Brake Switch", which I assume is the combination valve. That lights a
'Brake' light on the instrument cluster. The other is an unlabeled switch that lights a section of the Tell Tale display.
Bill Van Vlack
November 2015.
> Matt..
> lights a 'Brake' light on the instrument cluster. The other is an unlabeled switch that lights a section of the Tell Tale display.
Bill,
That switch is just a set of contacts on the outboard side of the parking brake lever. I have seen mine, but it is too close to the side of the cab
for me to do anything like make it actually work. If someday I have to have that lever off, then I might go after that as it would be nice to have.
Well, I know when I accidentally left my parking brake on while driving the coach from Texas, no lights lit. It was only after the brakes got hot and
I glided through a red light with NO brakes that the
"Brake" light came on.
So, on mine at least, I think there is a different (currently non-working) light to indicate stupidity, er, I mean leaving the parking brake on.
Coach is currently in my driveway on blocks undergoing brake renewal.
Greg Crawford
Knoxville, TN
1977 Royale
403
Rear Bath
American Eagle Wheels
Alex Sirum Quad bags
There are actually two brake lights on the dash. One in the speedometer cluster is actuated by the switch on the side of the parking bracket by the floor. The other is in the warning light cluster. This is actuated by the Brake combination Switch which is located in the brake lines on the frame inside the driver’s side front wheel. There is a wire on the top that comes on if the spindle inside the switch moves either forward or back indicating a failure or low fluid either in the front or rear brakes.
Frederick CO
> Greg Crawford
> Knoxville, TN
> 1977 Royale
> 403
> Rear Bath
There is no warning light that tells the driver that the e-brake is still
on, that the factory installed. There should be, that is for certain. If
you really want to glaze your rear drums, just drive a few miles with the
e-brake on. If you are rebuilding your brakes, always deglaze your drums.
Salem ,Oregon
On Fri, Aug 21, 2020, 4:33 PM Emery Stora via Gmclist <
> Emery Stora
> 77 Kingsley
> Frederick CO
> > On Aug 21, 2020, at 5:21 PM, Greg Crawford via Gmclist <
> and
> brake on.
> > Greg Crawford
> > Knoxville, TN
> > 1977 Royale
> > 403
> > Rear Bath
Jim — you are wrong on this one. I seldom have found you in error but you are this time.
I have a 1977 Kingsley. In the Owner’s Operating Manual for 1977 on page 24 t says:
To help remind you, the “Park Brake” light is designed to come on if the parking brake control is not fully released and the ignition key is on.
I believe you have a 1978 Royale. On page 18 of the 1978 Transmode manual it says:
I even checked the 1973 Owner’s Operating Manual and it also says:
So it appears that GMC installed this on all models.
Frederick, CO
> Salem ,Oregon
>> Emery Stora
>> 77 Kingsley
>> Frederick CO
>> and
>> brake on.
>>> Greg Crawford
>>> Knoxville, TN
>>> 1977 Royale
>>> 403
>>> Rear Bath
>>> GMCnet mailing list
James - it just occurred to me that perhaps your dash bulb is burned out for the parking brake warning light.
> Salem ,Oregon
>> Emery Stora
>> 77 Kingsley
>> Frederick CO
>> and
>> brake on.
>>> Greg Crawford
>>> Knoxville, TN
>>> 1977 Royale
>>> 403
>>> Rear Bath
>>> GMCnet mailing list
Emery's right on this one. I know because I broke my switch while removing and reinstalling the side panel next to the driver's seat. Hope I can
find a replacement or fab a substitute.
Rick Staples
Well son of a gun. I stand corrected. I provided information that misled
people out there, I am truly sorry. I have never seen a functioning warning
light for leaving the parking brake applied, so I just ASS U MED that there
wasn't one. I was wrong.
On Fri, Aug 21, 2020, 6:37 PM Richard H Staples via Gmclist <
> can
> Rick Staples
Darn you guys and your nit-picking!!! You should know I'd have to look at
the wiring diagram!
Emery, I hate to tell you this, but you got it bass ackards, at least on
the '75-'76 diagram: The lamp in the speedometer's connected to the
combination valve's differential pressure switch. The lamp in the
tell-tale cluster connects to the parking brake handle switch. I know,
that's bass ackards to how it OUGHT to be -- but it's the way it is.
Maybe some other years are different, but it's too late for me to go
checking tonight. :-)
Ken "Busy Body" H.
On Fri, Aug 21, 2020 at 9:45 PM James Hupy via Gmclist <
> Salem, Oregon
> Hope I
> > can
> > Rick Staples
> paths
Ken
Don’t be so dammed right all the time. Every time you post about 50 people grab their books to see if you are correct!
> the wiring diagram!
> Ken "Busy Body" H.
>> Jim Hupy
>> Salem, Oregon
>> Hope I
>>> can
>>> Rick Staples
>> paths
>>> GMCnet mailing list
Touche' :-)
On Sat, Aug 22, 2020 at 12:26 PM Emery Stora via Gmclist <
> Ken
> Emery Stora
> > On Aug 21, 2020, at 8:56 PM, Ken Henderson via Gmclist <
> at
> > the wiring diagram!
> > Ken "Busy Body" H.
> misled
> warning
> there
> >> Jim Hupy
> >> Salem, Oregon
> >> Hope I
> >>> can
> >>> Rick Staples
> >> paths
> >>> GMCnet mailing list
> >> GMCnet mailing list
