Heinz --
I must have hit save, not send on this message earlier this week. Sorry to
not notice.
I'm no chemist, but in my Mr. Wizard science experiment, I used a clean
glass pint jar (it was a canning jar) that was about 3/4 of the way full.
It bubbled. A lot. Not a rolling boil like you were making soup, but enough
that there was no question in my mind that I had severe moisture
contamination. I'm just curious if you see the same thing. I may just be
un-lucky.
I used a hot plate out in the garage. Had the same problem when I was headed
to the kitchen. BTW: I sneaked the candy thermometer out under my shirt.
I replaced the fluid with regular old everyday DOT 3 fluid. I got a gallon
from a local auto parts house.
Mark
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Heinz
> Wittenbecher
> Sent: Tuesday, May 18, 1999 10:14 PM
> To: gmcmotorhome
> Subject: Re: GMC: Brake Fluid Question
> Alright Mr Chemist... how big a sample is needed? and is it easy to tell
> that water is boiling off, i.e. at expected water boiling temp (212 or?).
> Does it just bubble?
> I'm not sure yet if I can get access to the kitchen with brakefluid in my
> hand
> What did you replace your Ford fluid with? What temp rating?
> TIA - Heinz
> > Heinz --
> > Get enough of a sample that you can heat it on an electric stove or
> > hotplate.
> > Stick in an accurate thermometer. See if water contamination
> boils off and
> > at what temp.
> > We'll all be interested in the results. I just took all my Ford
> fluid out
> > and it was rusty and black as can be.
> > Mark Grady
> > > [mailto
> > > Wittenbecher
> > > Sent: Tuesday, May 18, 1999 5:49 PM
> > > To: GMCnet
> > > Subject: GMC: Brake Fluid Question
> > > When I changed brakelines, etc I went to the Ford 550 degree DOT 3
> fluid.
> > > I now notice some discolorization in the master cylinder front brake
> > > reservoir portion. It's kinda rusty.
> > > Does it turn color when it contains moisture?
> > > Is it rust coming from the front calipers? They're only a couple of
> years
> > > since replace and/or serviced.
> > > Am I overdoing the 550? What's being used?
> > > TIA - Heinz
