Is our braking system able to use Dot 5? Been working to restore another vehicle and some of those guys have converted over to Dot 5 because of its
stability.
NO. Dot5 is a silicone based fluid. Do not try to convert to it.
You can however convert to DOT 5.1. You should convert to it. convert it. I did a seminar at the Tallahassee convention last year about brake fluids and 5.1. It is probably on the GMCMI web site. 5.1 is a glycol based brake fluid with additives to give a higher boiling point.
Easy to do. It is compatible with Dot 3 and Dot 4 fluids.
Frederick, CO
> stability.
> TG
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
