Brake drums
I'm no expert on the subject, but I understood that both the rotors and
drums are unique to the GMC.
Patrick
> In a message dated 7/20/2000 8:28:25 AM Eastern Daylight Time,
> > Does anyone know if the rear brake drums on
> > the GMC were used on any other standard GM vehicle?
> Hi Alan!
> Sure hope someone has the answer--I spent a considerable
> amount of time last
> year looking myself.
> Scott
Scott,
I hear ya' but, if there were an interchange, it would surprise me greatly
that someone in GMCMI had not already turned it up. Don't let me be a wet
blanket tho'...
Keep the faith,
patrick
> In a message dated 7/20/2000 8:39:50 AM Eastern Daylight Time,
> > the rotors and drums are unique to the GMC.
> Hi Patrick!
> Thats what I'm afraid of too! It is hard for me to think
> that GM being so large and with so many vehicles would
> engineer new molds and dies. I would think they used off
> the shelf stuff (Blanks) and drilled/milled the "blanks"
> to fit. Just my thoughts.
> Scott
Scott,
I've got a non-serviceable one I'd be happy to donate to the cause. Tell me
who and where and I'll pay for the shipping.
Patrick
> Maybe if a used brake drum and rotor was sent to Raybestes
> they could find what was used? What do you think Alan?
> What does anyone think?
Hi All
I just pulled my front and rear wheels to check bearings and brakes.
The good news is one rotor and one drum are still good.
The front bearings had .005" and .006" spacers. The .005 bearing shows
signs of running hot.
Three of the drums have the balancing weights missing. The weld mark that
originally held the weight is clearly visible but there is no sign of the
weight. One drum is also badly gouged. It is easy to spot the missing
weights because the hub rotates until the weld for the missing weight is on
top.
Has anyone been successful in getting drums rebalanced?
I am replacing hoses, wheel cylinders, springs, shoes, and anything else
easily removed on the back and callipers, rotors, and pads on the front.
The PO installed 80mm callipers but one leaks fluid. I am also rebuilding
the drive shafts and replacing the wheel studs while everything is off.
Dave Mumert
