did you look at the toad wiring diagram I put on the toad page??
Sorry about the cutout picture. but if you use a mirror and look under the
plastic panel, you will see how far to go with the cutout. I just cut it
out so it would not show from the front, and wide enough to get to the bolts.
gene
>GMCers
>Well, I am going to do it. I am not all that happy with my brakes yet so
>I am going back in. The only things I did not replace the first time was
>the combination valve and the booster. I am also going to add the electric
>vacuum pump. Does anybody have a better picture of the dash cut out I
>need to make that is better than the one on Gene's page? Thats Thursday's
>work.
>In the morning going to hang the base plates on the Sidekick and wire it
>for brake and turn signals. Anything I should look out for? Will do toad
>brakes some other time. I am connecting the wires for the toad brakes
>so they will be all in one connector.
>Friday I am planning on taking the steering box out and trying to adjust it.
>I have been over the service manual several times. Is there anything anybody
>would like to add?
>Last question: Got my turn signals and brake lights working by cleaning
>the connectors that nobody will talk to me about. Still want to solder them
>suckers up. The only problem left is that the dash indicator lights are not
>working. Anything I should check first? Flasher clicks and turn signals
>work but the dash lights dont come on.
>Sorry for so many questions---been a long day. Trying to get the lady on
>the road by June.
>Take Care
>Arch 76 GB IL
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
gene
>GMCers
>work.
>would like to add?
>the road by June.
>Take Care
>Arch 76 GB IL
mr.erf
